Opening a Cartoni Head at DVinfo.net
Old May 20th, 2014, 05:05 PM   #1
Does anyone know how to open a Cartoni head? I have a Cartoni Beta and the tilt brake has malfunctioned. It's extremely tight and cannot be moved by had. Also, i can tilt the head, only with a ton of pressure, and it's not fluid at all.
Corey Williams is offline   Reply With Quote
Old April 12th, 2016, 01:57 PM   #2
Re: Opening a Cartoni Head
Hi Corey,
I know this is an old thread and I expect you have solved your issue already.
It looks like you have to remove the platform and the platform support (base plate). Then there should be a pin you have to drive out that locates the side casing on the central shaft. that will access the tilt brake assembly once the cover is off.
Haven't seen a Beta here although we are authorized for Cartoni service.
Hope that helps.
ian@ijes.ca
Ian Johnson is offline   Reply
