IR torch with Sony HVR-A1 at DVinfo.net
Under Water, Over Land
Old June 2nd, 2009, 01:52 PM   #1
Hi,
I know there's a few of you out there using sony cams for the nightshot function. I placed an order for a mini IR flashlight the other day from HK - only £13 shipped. Search on ebay for "IR Infrared Illuminator 28 LED" anyway, it's perfect - built like a maglite and small enough to mount on a cheapie sony mic holder. It's 28 LED's are a massive improvement over the built-in LED, and gives a wide spread that still gives the intensity to focus on objects about 25 feet away.
Pic attached
Hope it helps!
Rob Evans is offline   Reply With Quote
Old June 2nd, 2009, 02:17 PM   #2
Any video samples of it in use? Maybe compare it with the standard IR LEDs? Looks very nice.
Edward Carlson is offline   Reply With Quote
Old June 2nd, 2009, 02:19 PM   #3
Will try and hook some up when it gets dark ;-)
Old June 2nd, 2009, 04:10 PM   #4
Here you go, i've switched it on and off so you can see the difference. Ok, it's no floodlamp, but it's very mobile!!
Old June 5th, 2009, 12:20 PM   #5
Rob,
Thanks for sharing that!!!
I have an old D8 that has night function that i could use for the odd thing now instead of leaving it on the shelf as a paper weight!!! Will have to try it!
DATS ALL FOLKS
Dale W. Guthormsen
Dale Guthormsen is offline   Reply
