How to minimize water on the housing glass at DVinfo.net
Under Water, Over Land
Old March 10th, 2010, 01:17 PM   #1
I shoot fly fishing videos, and a lot of times I have the desire to transition a shot from below water to above water, but usually only get a second or so after I pull the camera out of the water before the housing's glass has the water run off and leaves drops of water across the face of the glass. Is there something I can use that will allow the water to sheet off properly without leaving unsightly drops?
Craig Coston is offline   Reply With Quote
Old March 11th, 2010, 06:05 AM   #2
Mate, This will sound strange but I've heard surf photographers lick their lenses, I'm serious.... I've never tried it as most of my water video / stills are taken underwater.
Al
Alan Melville is offline   Reply With Quote
Old March 11th, 2010, 12:19 PM   #3
just use RainX on it, buy at any auto parts store
John Abbey is offline   Reply With Quote
Old March 11th, 2010, 04:51 PM   #4
If you can pack one in use a small aquarium just big enough to put the camera in and sink it below the surface of the water.
Keeps your camera dry and gives you the transition shots of below & above without a special housing and safely keeps your equipment dry also.
Pat Miller is offline   Reply With Quote
Old March 11th, 2010, 07:00 PM   #5
When I was recording underwater shots for my Chinook salmon filmed, I spread shaving cream on the inside of the underwater lens housing and than would wipe it off with a lens cleaning cloth, this kept it from fogging up. About every 2 hours I would reapply. This may work for you by applying on both sides.
Leon Lorenz
Canadian Wildlife Productions: Grizzly Bears, Bighorm Sheep in Alberta & BC Rockies DVD Videos
Leon Lorenz is offline   Reply With Quote
Old March 12th, 2010, 03:10 AM   #6
I have had the same problem and I think too, that the nano spray for spraying on the auto glass will do the job - I just have not tried it yet...
Bo Skelmose is offline   Reply With Quote
Old March 14th, 2010, 05:51 PM   #7
Pulp of an apple rubbed on the lens. It does wash off after a while but works great. Try it.
Rambo
Ian Newland is offline   Reply With Quote
Old March 14th, 2010, 05:58 PM   #8
The best thing I find is spit... spit on the port / lick it then it will be fine for a minute or so.
RainX works ok but I reckon spit does just as good a job.
J
Jonathan Shaw is offline   Reply
