#31 | |
#32 |
''Raynox seems to breeze by this issue on its website and I think they should not list their lenses as suitable for cameras, with which they vignette at all points of the zoom.''
This is bad news. So Raynox are selling a 2.2x tele converter with a 62 mm attachment thread as suitable for the 72 mm filter thread of the Z1?!? |
#33 | |
Steve McDonald https://onedrive.com/?cid=229807ce52dd4fe0 http://www.flickr.com/photos/22121562@N00/ http://www.vimeo.com/user458315/videos |
#34 |
Raynox 2.2x
Has anyone had a different experience with this adapter? As I said previously, our quick test could not get rid of the vignetting anywhere in the Z1 zoom.
We're picking up another Z1 this week- which we'll keep. And do another test. I'll report back on this test also. Wayne |
#35 |
Yes, the Z1 has the same 72mm filter thread. If the front element of the lens is any where near this diameter, I should have thought that serious vignetting was inevitable if you put what amounts to a 62mm mask in front of the lens - the extra spacing generated by the step down ring will simply make matters worse.
After all, as has been noted above, putting a teleconvertor which is designed specifically for the lens in question on the the front leads to vignetting at all but the longer end of the zoom. The Sony 1.7x is better from the vignetting point of view than the Century 2x on the VX2100 for which they were designed, but the diameter of the glass is far greater in the Sony. Last edited by Alan Craven; April 12th, 2006 at 08:18 AM. |
#36 | |
#37 |
Amazing! Is there not even any darkening at the corners of the frame?
It is a pity that Century cannot provide that kind of performance with convertors which are used on the intended camera. |
#38 |
I suppose there might be slight darkening at some point, but I really haven't noticed it in any footage I've edited (FWIW, I shot HDV but captured as SD using in-camera firewire downconversion). I used the Z1's allscan mode and pointed at a bright area to determine the maximum zoom point. Of course you need to remember that this lens costs around $,1000...
#39 |
Presumably it works because the diameter of the lens elements is large?
The rear element of the Century 2X is 39mm diameter - a lot less than the 58mm thread - while the front element diameter is 75mm. The comparable figures for the Sony 1.7X are 37mm and 88mm, and this allows you to zoom out a lot further than the Century |
#40 |
2x cent/1.6 canon tc
Well,
While waiting for my gl2 to return I have been using my xl2 with the canon base lens mount 1.7 teleconverter. I believe that the canon converter when at the distance is not as clean of an image as the Century 2x when on my gl2. The standard lens on both is an interesting comparison when zoomed. The xl2 does seem to hve finer lines on the objects in focus than the gl2 when at the distance. the more I dabble with these the more I realize how important it is to just get closer!!! I guess the real test is to put a century 2x on the xl2 for a final test. Dale Guthormsen
DATS ALL FOLKS Dale W. Guthormsen |
#41 |
Old Boot
Dale, did you post any Xm2/XL2 Century 2x footage? Just invoiced a client . .I'm feeling frisky!!
Grazie |
#42 |
Grazie,
No I never did post some footage with the century 2x. I am on holidays for the next two months and I will see if I can post some images. Of interest is that I have my xl2 with the 1.6 plex and the gl2 with the 2plex from century. I will see if I can post some comparisons. I kind of like the century better as it softens less at the further distances. I have not printed stills for comparison, so it is only a feeling. I will try to do something more constructive with them this week. Dale
#43 |
Old Boot
Thanks Dale.
#44 |
Graham,
Yesterday I got out and did some comparison footage. I got some footage of an upland plover that shows the level of detail through each lens. I put the footage on the time line and could post a still of the same bird through each camera, the xl with the 1.6 and the gl with the 2x century. Is there a place on this forum you can post a still?? I coluld make a wmv file of both to email anyone that wanted to see the difference in video.
#45 |
Graham,
Oh yea, today I will run a test on a manual canon 300mm lens attached with a non lens converter.
