Link to Uploaded films ON DVInfo - Page 2 at DVinfo.net
The UWOL Challenge
Old February 25th, 2009, 05:47 AM   #16
Since they moved the IP on us, I've had issues with being able to do things. Sometimes the files show up so I can move them, other times it doesn't allow me to get into any directories. Still other times it shows there are no files. Talk about panic on a stick! :)
The change came at a bad time as we were just getting into the first phase of the long form.
If you upload any videos just post here that you did and I'll see if I can move them into the long form directory.
Thanks for being patient. I'm not sure if we're out of the woods yet or not. :)
--==Kevin==--
Old February 25th, 2009, 06:19 AM   #17
I uploaded mine about 12 hours ago - it's not showing on the index.
Canon XH A1; Canon XF100; Nikon D800
Annie Haycock is offline   Reply With Quote
Old February 25th, 2009, 06:42 AM   #18
Hi Kevin
Uploaded mine yesterday - also not showing on index.
Marj
Old February 25th, 2009, 03:40 PM   #19
Ok, let me go in and see if I can find them. This IP move has created a lot of havoc and I don't think we've seen the last of it yet.
--==Kevin==--
Old February 25th, 2009, 03:42 PM   #20
Holy smokes it worked!!!! :)
Ok, did I miss anyone?
--==Kevin==--
Old May 12th, 2009, 03:23 PM   #21
I'm moving the long form files into the longform directory.
Bob, I had to add a 2 to your filename since it was the same name as the other one. :)
--==Kevin==--
Old May 14th, 2009, 01:59 AM   #22
Kevin, I uploaded tonight...
Old May 14th, 2009, 04:26 AM   #23
I uploaded this morning...it still before midnight in Johnston Atoll :)
www.tahoestarr.com
Jeff Hendricks is offline   Reply With Quote
Old May 14th, 2009, 04:31 AM   #24
Ok, I was finally able to get back in. For some reason when I get in the directory it shows that nothing is there. But everything in there has now been moved to the long form directory.
--==Kevin==--
Old May 14th, 2009, 07:55 AM   #25
Kevin,
Do you happen to see mine on there (Hendricks_The Pilgrimage)? it ended up finishing loading at around 3:45am Pacific time
Jeff
www.tahoestarr.com
Old May 14th, 2009, 08:11 AM   #26
go to sleep early one night and the pixies pull it together to make everything work.
the hallmark of success is to make yourself irrelevant...
just fyi, Cat, I didn't extend the deadline...I told everyone who has a good excuse to contact me and plead their case...
...so of course, half a dozen of you did...that's how it goes when you open that door a crack!
I don't/didn't want to extend the deadline because then long form bleeds into short form and that is not fair to the short form....
I built these deadlines this way for a reason, even though no one ever believes that there is method to my madness....
Old May 14th, 2009, 09:22 AM   #27
O.K. Meryem!
I laughed at your fyi directed at me. Why single me out? I'm thrilled that your good graces are covering this forum. That means when I need a little slack,hopefully I can successfully plead my case in an e-mail too!
Now if you want to get sticky.... which rule was it that says you must submit at least 7 minutes of material for every round except the first? Hopefully we can plead our cases in an e-mail on that one too ;-).
I love this forum!
Cato
Old May 14th, 2009, 09:25 AM   #28
I like that! In a pinch I'm more successful than I ever thought I was! ;-).
Catherine Russell is offline   Reply
