Can my computer be a monitor? at DVinfo.net
Old June 9th, 2007, 10:39 AM   #1
For an onlocation shoot I'm not shooting in HD, using DV with the jvc gy-hd100u. I just need a monitor for the basics....
Is anyone using their laptop as a monitor? What program are you using on laptop to view while shooting?
Lisa
Lisa Bennett is offline   Reply With Quote
Old June 9th, 2007, 11:07 AM   #2
DV Rack is what we use and I have no complaints. Cheers.
Craig Roblewsky is offline   Reply With Quote
Old June 12th, 2007, 11:31 AM   #3
What about using a conventional laptop as a HDV monitor, is it possible?
Andris Krastins is offline   Reply With Quote
Old June 15th, 2007, 12:30 PM   #4
I also use DVrack HD on my laptop..but I found it to be good when looking at the meters and for clipping purposes. In addition to have it monitor overall settings..but for critical focusing..it is not as good as my Nebtek because DV compression kills the resolution when feeding the output to the laptop using firewire.
Canon XHA1, SGpro,Flip,FF, RR Mattebox, Nebtek V-R70p-HDA with Canon, Nikkor Primes 24mm f2.8, 28mm f2.8, 35mm f2.0, 50mm f1.4, 85mm f1.4, 105mm f1.8, 135mm f2.0, and 300mm f4.0.
Cary Lee is offline   Reply With Quote
Old June 19th, 2007, 12:32 PM   #5
I might be missing something, but wouldn't the DV compression also be what you see on tape? And if so, wouldn't focusing at the same net "resolution" as the final product be adequate?
I can understand how the compression could make it harder to focus accurately than the raw analog image, but would think that you wouldn't see the difference in the final images.
I'm not in any way taking issue with what you've said, just trying to understand better.
Last edited by Jim Andrada; June 19th, 2007 at 12:33 PM. Reason: subscribe to reponses
Old June 28th, 2007, 12:33 AM   #6
I wanted to get more info about the same thing. I think if you shoot in 720P an Lcd montor can handle that because it
has those resolution capabilities ( depending on what brand of monitor you have ), but I think you would still need a HDMI connector.
I'm hoping someone with more knowledge can post here with more info. My monitor just broke yesterday and I'm doing this through my T.V.
Robert Thomas Baumer is offline   Reply With Quote
Old June 28th, 2007, 01:19 AM   #7
Computer monitors have been "high definition" for a long time...
Any 17-19" LCD will do 1280 x 1024 (which will fit 1280 x 720 with letterbox 1:1 pixel scale)
Most bigger CRT's go up to 1600 x 1200... some 21" go 2048 x 1568 (I think that's the resolution, I'm guessing)
I have a widescreen 24" CRT that does 1920 x 1200 for now... Fits 1080i with letterbox :) (16:10 ratio, not 16:9)
If you got a spare LCD, it should work through DVI... snag an HDMI to DVI cable... I think that'd work..
Joe Busch is offline   Reply
