#1 | |||
Re: 6th Wedding - Critique
Hi Glen,
it's not bad at all for someone who's starting out. You've got a nice mixture of shots there. There is one problem though, I think you've shot the wedding in 25p and then you've slowed it down (unless it's my computer playing up!). I don't think that's a good idea as the image begins to look jerky. Try filming in 50p if you want slowmo. |
I'm a fan of slow motion but that slow mo looks ridiculous. Jerky footage like that isn't acceptable ... I would only use it as a 'life saver' if I only had a few seconds of an essential shot that I needed, otherwise for slo mo work you NEED to be filming at 50p.
Have the couple/family seen this yet? you might get a complaint about that slo mo. Otherwise it's a good piece of work with a variety of shots. The colour grading is nice too. Not dull like you usually see. |
thanks, yes the slowmo is always a bit of a drag, but i use a 600d for a lot of the shots so no chance of 50p on that ;-( i do have a locked off mc50 for church and speeches - so dont use that for slowmo obviously..........will simply filming in 50p make all the difference???
#5 |
been told that my 600d can do 720p at 50fps, so if i set shutter speed to 1/100 i should then be able to slow down in vegas faitly simply.....quick quesiton would it be easier to use all my cameras on 720p setting (regardless of 25p/50p/50i etc) , or shoot all others in 1080p, which will then drop onto a 720p timeline and enable me to zoom if needed...................
#6 |
If it means you won't get that juddery image. You are definitely better off shooting at 720p.
Are you delivering on blu ray or DVD ? or both ? Either way, a good edit of 720p footage will be much better for you (unless you want to completely change the camera you use and upgrade). I've seen awful 1080p edits and film-like cinematic 720p edits because the camera man knows what settings to use and makes good use of available light and so forth. Definitely film in 50p 720p if your going to slow down footage a lot as that juddery image is letting you down big time. |
#7 |
Glen,
I have a 700d and if I want to use slomo I use 720p 50. In the ceremony I use 1080p 25 as the crop is more important for me in a church. I edit in 720p 25 as evrything gts put on a DVD here and a 720 mov is more than enough for a computer. So in answer to your questions, I change throughout the day but remember to keep an eye on what setting you are using and the shutter speed. |
#8 |
Also bear in mind that 720p will give you a noticeable resolution hit and adds even more moire, in the worst case it will look bad but 720p 50p slows down much better then 1080p 50p.
If you want 50p with intention to slow down and a high quality image then it's better to get a camera then can give you that, like the panasonic gh3 can. It was one of the reasons why I switched from the 550d to a gh3, my slowmotion footage on the steadicam with the gh3 are like night and day now compared to my 550d. |
#9 |
If you have good software, 1080/25p can be slowed down without too much trouble.
After Effects - use the Time Warp - set the quality to 100% and it takes a while but is generally pretty good. FCPX / Motion - make sure you turn on Optical Flow. Twixtor Not everything can be slowed down without artefacts, but most footage can to the point where anyone watching that doesn't know what they are looking for will never have a problem. I've slowed some 1080/25p down to 10% and it looked awesome while others have had a problem going to only 50%. You have to try each clip to see how it goes.
Qualified UAV Pilot with CAA PFAW Aerial Photo / Aerial Video | Corporate Video Production |
#10 |
I've only just joined and have yet to shoot my first wedding (that's in April). My recommendation would be to try to make the most of the natural light from windows in your earlier shots... I know this is from an amateur perspective, but even just turning the chair for the make up would have made a world of a difference as far as I can tell... maybe just me though. Otherwise, enjoyed it, particularly the end, you finished stronger than you started by quite some margin I think... and that's because the emotion of the day began to pour through.
#11 |
I actually think that, given that music and feel of the shots, and the colors, I would try it *without* the slow-mo.
