Benefits of multiple audio sources at DVinfo.net
Old October 7th, 2007, 01:16 PM   #1
I filmed my 5th wedding on Saturday. Used 4 irivers: one on the sound board, one on the officiant, one on the groom, and one on a mic stand for readings.
I don't know why but I got nothing at all from the one on the sound board...so if I had relied on it I would have been sunk. Haven't downloaded everything yet but have the officiant great - picks up the couples vows very well.
For the reception I put on on the mic stand for speeches. They have come out as clear as a bell.
Renton Maclachlan is offline   Reply With Quote
Old October 9th, 2007, 02:47 AM   #2
Could it be that the soundboard was mic level out and you had the iriver on line level?
Old October 9th, 2007, 07:31 AM   #3
Not if you had followed one of the golden rules of audio recording: always monitor what you record. I know this is easier said than done during the hectic activites of a wedding, especially with multiple recorders, but a worthwhile investment from my experience.
- Martin
Martin Pauly
Martin Pauly is offline   Reply With Quote
Old October 9th, 2007, 11:06 AM   #4
Agreed, iRivers ahve been known to have input problems with soundboards. Also you have to make sure that your iRiver is set to Line in in the menu.
It's always a good idea to do a sound check first with the soundboard to make sure that your levels are correct.
I agree also as to always at least monitor one audio source. This is why it would be a good idea to have a wireless system for you audio, which can be sent and monitored in your cam.
I use a wireless on groom, and 3 different recorders (depending on recording needs) Edirol R09 or Zoom H4/H2 on mic stand to record musicians, R09 on podium to record readings, backup recorder on groom in case wireless fails.
I have also used Edirol R4 (4 track HD recorder) at podium (mic in Ch1) to record readings, wireless in CH2 (from groom), wireless on officiant or musicians (CH3/4). The send a mixdown (via RCA Line out) to my camera (wireless).
Mostly for weddings though I use method #1 (3-4 recorders and wireless) and have had no issues. I rarely ever use the church board as I have not had the best results in past shoots.
Michael
www.lvpvideo.com
Michael Liebergot is offline   Reply With Quote
Old October 9th, 2007, 12:57 PM   #5
Re the sound board no go: I can see now there are a number of options as to what happened.
Also, this is the first time I had ever tried this and didn't know how to check things out, and the sound man was a fill in and had never done one of these connections before.
It doesn't worry me I got no audio from it because I was not relying on it, but is a good lesson along the way, and I know better what to do next time.
