Special Tripod at DVinfo.net
Old June 17th, 2008, 10:07 PM   #1
Special Tripod
I'm wanting to place an unmanned camera in the middle of the isle on a tripod that has a small footprint (18" or so) and where the bottom of the camera is maybe 4" off of the floor. This is for an effect shot as the bridesmaids and groomsmen, plus the bride and father practically walk right over it during the processional. I need something real stable so it doesn't fall over if the brides dress covers it up as she goes down the isle.
Any reccommendations on brands and/or other ideas.
Tom Sessions is offline   Reply With Quote
Old June 17th, 2008, 11:13 PM   #2
My only thought is a table-top tripod, but that's not going to be rock solid if the bride's dress makes contact with it (which it probably would).
Black Label Films
www.blacklabelweddingfilms.com
Travis Cossel is offline   Reply With Quote
Old June 17th, 2008, 11:29 PM   #3
I wouldn't think it would "need" to be a tripod... would it? Couldn't you just find an appropriately sized [cardboard] box, then put sandbags in it to weight it down and support/stabilize the camera?
What make/model of camera is being used for this?
Andrew Kufahl is offline   Reply With Quote
Old June 17th, 2008, 11:50 PM   #4
Spiderbrace
I know it's not a tripod, but would this be any use (resting on the floor)?
http://www.spiderbrace.com
Old June 18th, 2008, 12:07 AM   #5
A beanbag might be an answer - you know, one of those that sctews into the tripod socket. Other than that I'd use one of those very heavy short microphone stands - and hope the camera doesn't get kicked.
Old June 18th, 2008, 12:50 AM   #6
We use Manfrotto self standing monopods and gaffer tape the legs to the floor.
www.springproductions.co.uk
Tony Spring is offline   Reply With Quote
Old June 18th, 2008, 01:27 AM   #7
Maybe you guys missed it but he said he wants it like 4 inches off of the ground. I think a monopod is still going to be too tall and a cardboard box with sandbags is going to be too large and obtrusive, not to mention kind of tacky for a wedding.
I own a Spiderbrace, and I don't think this will work well either for 2 reasons. First, it's likely to get kicked with people walking past it and there's not much of a way to secure it solidly to a floor. Second, it's not actually level with the ground when you place it on the ground. I've tried to do shots with it on the ground but I always have to compensate manually because it will lean to the side due to the way the arms are.
Black Label Films
Old June 18th, 2008, 02:03 AM   #8
I just found a Manfrotto Hi-Hat 529B. This should work perfectly.
Thanks for your suggestions.
Old June 18th, 2008, 02:11 AM   #9
Cool looking tripod! That's what I had in mind when I suggested a table-top tripod, although that one looks nicer than most I've seen.
Make sure you post a clip to show off the footage and let us know how the shoot went.
Black Label Films
Old June 18th, 2008, 02:27 AM   #10
Tom -
Take a look at the Ultrapod and the Ultrapod II - I keep those, a pedco clamp pod, plus a couple cheaper clamp type camera supports in my "I have no idea why I have this until I need it" portion of the kit. I typically shoot smaller cams, and the aforementioned minipods are perfect.
The clamp type pods saved my bacon more than once - all you need is a sturdy pipe, shelf, railing, etc. Most have a 90 degree swivel head of some sort, and could be clamped to a pew or chair to do exactly what you want.
I even have a suction cup type mount in the aforementioned kit... still have no idea why... I pick up these odd sorts of "orphan" camera mounts on eBay for next to nothing (never more than 1/10th of what that Manfrotto you referenced runs...), and then just wait for the proper moment to whip them out and go "AH-HA"!
Old June 18th, 2008, 02:29 AM   #11
I do a similar shot when filming. I use a bogen backlight stand, Bogen / Manfrotto484RC2 Mini Ballhead, ManfrottoRapid Adapter - 5/8" Stud to 1/4-20" Thread combo. What's great is I use these accessories in other applications during the reception also.
Joel Campos
studio red www.studioredweddingcinema.com
Joel Campos is offline   Reply With Quote
Old June 18th, 2008, 03:19 AM   #12
I use a stickypod for these kind of things, My work is mainly in theatres, so I have a couple of these that I fit with a consumer DV camera, and just place on stage, up-shots of the drums, hidden behind monitors, etc. The rubber pads act as a shock absorber, and mounting the knuckle directly to the plate alows a really low angle. In fact, I rarely stick the things onto vehicles, and just use them as the OP is looking for - low angle stable tripods.
Old June 18th, 2008, 06:37 AM   #13
Are you really going to leave this thing sitting on the floor as each pair straddles it? Sounds great in theory but I doubt an entire wedding party will manage to miss it.
I have see one videographer do something similar though... he has somebody sit in the last pew, then as the bride walks by they immediately sit it on the floor behind her (on a little tripod about 4" high) where it stays the whole ceremony.
Rick Steele is offline   Reply With Quote
Old June 18th, 2008, 11:56 AM   #14
Yeah, I could see it maybe surviving the wedding part walking by (maybe), but I would bet the bride's dress is going to catch on it.
Black Label Films
Old June 18th, 2008, 10:53 PM   #15
I'll try a couple of fake runs here at the office with a dress from my wife's collection just to see what might happen....I'll wear the dress...hee, hee
