New blue fx users... at DVinfo.net
Old August 16th, 2009, 05:52 PM   #1
I've been having serious issues regarding interlacing lines on the clips that i've used the color corrector on.. Everything looks fine in the timeline but when I go to export it looks like crap. Every now and then it comes out fine. Like one out of every ten exports. I dont get it. Just curious if anyone else had the same problem.
Steve
Stephen J. Williams is offline   Reply With Quote
Old August 16th, 2009, 08:35 PM   #2
I haven't had any issues. I'm on a Mac... and not sure if that has anything to do with it.
I like my oatmeal lumpy.
Blake Cavett is offline   Reply With Quote
Old August 16th, 2009, 08:40 PM   #3
Thanks Blake...I figured it out...
I'm using a mac with FCP. All I had to do was make sure the that the color fixer filter was the before all of the others (mainly before the de-interlace filter). Easy fix, but took a while.
Steve
Old August 17th, 2009, 10:32 AM   #4
That brings up a good more general point. Some filters don't coexist well with other filters. This is especially true with filters like Mercalli and Neat Video. It helps to use a near lossless editing format so you can do multi-rendering passes if necessary.
Jim Snow is offline   Reply With Quote
Old August 17th, 2009, 11:10 AM   #5
Hey Stephen, glad it worked out.
Since you're on FCP, let me ask you: Do your sequences render clips that have NuBlue applied to them?
Mine won't render.
Old August 17th, 2009, 02:41 PM   #6
Mine won't render.
Thats odd.. My render just fine. I dont really use many filters though. Just mainly the color fixer. i've also played around with the blemish remover (thought that was pretty cool).
Good luck. Hope you figure it out.
Steve
