DVD Burning hiccup? at DVinfo.net
Old May 13th, 2010, 08:34 PM   #1
DVD Burning hiccup?
I know this might belong more in the technical forum, but I figured since I'm working on a wedding DVD right now and some of you guys use the same stuff I'm using, I thought I would see if you've ever run into this problem...
I use DVD studio Pro on my Mac Pro tower to burn my DVDs. However, about every third or fourth DVD, I get a formatting error message, and I basically have to trash that DVD. And I can count on it pretty regularly -- I did a dance when I burned five in a row without problems.
Has this happened to anyone else?
Is it a possible problem with DVDSP? A problem with the DVD's I'm using? A problem with my burner?
Any educated responses or shots in the dark are welcome.
Excuse the double posts, as I'm new at this thing.
Jordan Meserole is offline   Reply With Quote
Old May 15th, 2010, 03:24 AM   #2
I use dvd studio pro to build my menus and I use compressor to encode my assets. I use toast to actually burn the dvd. Toast will burn mutiple dvds as batch and seems very reliable. I just use the build function in dvd studio pro and then burn the video ts files in toast.
Harry Christensen is offline   Reply
