Multiple Camera Operators? at DVinfo.net
Old October 13th, 2010, 02:30 PM   #1
I have been filming weddings for 6 years and have only used another operator for a few weddings. I use 3 cameras. 1 is static, for a wide shot of the venue and for safety. 2 are for closer up shots, although I normally position them so that I can get to them without disrupting things. I have never had a complaint about being obtrusive. From reading these boards, it appears that the majority film weddings with two or more camera operators during the ceremony, but I was not sure. How do you film the ceremony?
www.clarkvideoproductions.com
Michael Clark is offline   Reply With Quote
Old October 13th, 2010, 05:09 PM   #2
Hi Michael
Two cams and just me!!! At the ceremony I have one for just the happy couple and the officiant and that also does both radio mics. My 2nd cam is on-shoulder for guest cutaways and wide shots.
I look at it this way. If I foul up it's my fault and I need to deal with the client. If my assistant fouls up it's STILL my fault as I'm the main shooter!!! Bear in mind that you can usually get away with just one camera at the reception for everything but the speeches so I still prefer the single op approach unless it's your well trained wife/girl friend.
Seriously, are you going to end up with a better product??? It's certainly going to cost your more to pay an assistant!! From a business point of view I prefer just me!!
Chris
Old October 14th, 2010, 09:24 AM   #3
2-3 cams. The main cam on tripod/handheld with 2 radio mic. Cam 2 is static semiwide mainly for capturing good sterio audio. Cam 3 is static wide, either at the back or placed by the altar pointing towards the audience. In the editing I use almost all the footage from the manned camera, only when changing positions and framing that I use cam 2/3. I also get shots of guests and use it two og three times for cutaway insted of using the same frame from cam 2/3. Be careful not to use peoples gestures that easy is to identify if you use it again.
http://akfilm.is
Asvaldur Kristjansson is offline   Reply With Quote
Old October 14th, 2010, 10:01 AM   #4
Ceremony is up to 4 cams with two operators (well trained son!) and assistant (well trained wife!).
Reception is generally two cameras with three for the speeches (one static wide, two for close ups of the speaker and/or cut away).
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply
