DSLR wedding question - Page 2 at DVinfo.net
Old December 7th, 2011, 01:22 PM   #16
Re: DSLR wedding question
Originally Posted by Taky Cheung View Post
David, you have to format the SD card making it bootable. Then install the ML software files onto the SD card. So if you have 10 SD cards, all of them will need to have ML on them.
This is great news (how smooth the process is)! I did not know this. I just did some more research...there is a ton of helpful info on the wiki page, including install/removal instructions.
JS
John Stakes is offline   Reply With Quote
Old December 7th, 2011, 01:26 PM   #17
It is actually way more easier than you think =) Go download the EOScard.exe file to make the disk bootable. Then copy and paste the ML files over!
With ML, it makes DSLR more and more like a full function camcorder. I made a donation to them. If you found it helps you with your business, you should donate too! =)
LA Color Pros Blog
Taky Cheung is offline   Reply
