#16 | |
Re: Wedding Guest Messages with DSLR
www.videoproductions.ie |
#17 |
Hey all,
Few thoughts on this subject. First, the H6N coming out for $400 looks promising.. with removable mic types on the front, plus 4 XLRs, recording to 6 audio channels.. to me it's on the list of things to get. I currently have a Tascam DR-40 and works great, except I bent the dang headphone jack (which all plugs were locking SDI like plugs!!). So I can still record but want the 6 channels anyway. What about a BeachTek or similar 2XLR or 3XLR mixer/pre-amp/phantom powered? You use that, feed the output to the DSLR input and you can record two or so XLR mics for great audio right on the camea, don't need to sync or anything. It works well, although I still prefer the external recorders along with a sync track on the camera. |
#18 |
Have a look at JuicedLink. They make good quality mic preamp/mixers that allow XLR inputs to be used on cameras without them. I use a riggy with my GH3. I end up with better quality than my Sony HVR Z5 which uses compressed Dolby audio, whereas the GH3 is uncompressed. The preamps on the riggy are of better quality than your typical Zoom and Tascam recorders, and I get the assurance of headphone monitoring on the camera which I consider essential.
Cheers, Mark
MW |
#19 |
That was the other one..Juicelink. Couldn't remember the name of it. If you want near high-end quality, pairing a JuiceLink with an external recorder will give outstanding quality. Like the other guy said, the pre-amps are no doubt a bit better on a device that costs more than a recorder and basically provides pre-amps and mixing of channels and that's it. I am considering the Juicy with the H6N down the road, but will need 3 Juicy's for the 6 inputs on the H6n (probably just get 2 and use 4 inputs + mic on the H6N).
#20 |
"The pre-amps are no doubt a bit better on a device that costs more than a recorder and basically provides pre-amps and mixing of channels and that's it. I am considering the Juicy with the H6N down the road, but will need 3 Juicy's for the 6 inputs on the H6n (probably just get 2 and use 4 inputs + mic on the H6N)."
There's nothing to gain by connecting the juicedlink into the Zoom. That would just be an unwieldy monster. It plugs directly into the DSLR, so you don't need a separate recorder or sync'ing up later. You do need a camera with a headphone output though to check what's going in. To me the H6 looks way too big for a DSLR rig. You may as well have a full sized ENG camera. 6 inputs is pretty cool though! I use an H2 and an H4 and sometimes also a tiny little old iRiver mp3 recorder with a lav mic. Sometimes I even manage to hit record on them all in my pre-wedding panic :) Sorry to the OP for getting a bit off track. Cheers
MW Last edited by Mark Whittle; May 30th, 2013 at 05:48 PM. Reason: Additional comment |
#21 |
There is no substitute for getting the microphone as close to the mouth of the speaker as possible. If you don't have a skilled boom operator the only other choice is a lav mic. Connect it to a wireless unit or any of the digital recorders & you are set.
#22 |
I'm so glad Nigel said that. Everyone seems to want gizmos to make thin, distant and weak audio sound good. Get the mic in close, and forget all these worries about preamp noise, and sleep easier! You rarely see people who wish to shoot everything on the lens wide setting, then spend time trying to avoid the extra noise, and loss of definition when you have to crop the image in the edit and expand it to zoom in!
