Sending HD Component or HDMI over long distance at DVinfo.net
Old March 19th, 2016, 04:59 PM   #1
Hey everyone,
I am working on a streaming set-up for a baseball field. We are using a Sony HVR-V1U camera in Left-Center field, and a Sony PDW-F700 on the roof of the press-box.
The Camera in Left-Center field will be a static locked off (un-manned) shot of the pitcher/batter.
Both cameras need to be ran back to the press box behind the plate. We are using a BMD ATEM switcher. Obviously the F700 on the roof of the press-box has HDSDI out which we will run back to the switcher with no problems.
But I need a solution to run (component or HDMI) 1080i from our Sony HVR-V1U camera in Left-Center back to the press box (aprox. 425 feet).
The obvious choice would be fiber, but that seems quite expensive. Has anyone had any experience with HD over Cat5?
I found this: Active Component Video Balun Kit | Muxlab
It claims to be able to send HD component up to 500 feet over Cat5. If this works we would take a BMD mini converter and convert the component to SDI. Would this work?
All of this is being set-up for internet live streaming. We want HD, but quality isn't a major deal, were not talking about anything in 3G 1080p here...
Any suggestions, Help would be greatly appreciated.
Zach Legleiter is offline   Reply With Quote
Old March 19th, 2016, 06:19 PM   #2
Wireless?
The Teradek Bolt is a zero delay (< 1ms) wireless video system that transmits uncompressed 1080p60, 4:2:2 video up to 2,000ft over the unlicensed 5GHz band. The Bolt line-up comes in 3 ranges: 300, 600, and 2,000ft.
Teradek Bolt Uncompressed Wireless Video Transmitter with Zero Delay | HD-SDI or HDMI Models Available | Teradek, LLC - Wireless HD Video
Stephen Brenner is offline   Reply With Quote
Old March 19th, 2016, 06:26 PM   #3
Re: Sending HD Component or HDMI over long distance
I wish we could afford a Bolt... We have a $500.00 budget to make this happen.
Old March 19th, 2016, 06:27 PM   #4
How about convert HDMI to SDI, run it 250 ft, then drop a reclocking DA, then run it the rest of the way?
Total cost: BM HDMI to SDI converter: $185.25. BM SDI DA: $185.25. 500 ft Belden 1505A: $225. 4x Kings 2065-2-9 BNC connector: $7.56. Total: $603.06
The component balun solution: Muxlab 500090 $446.95. BM Component to SDI converter: $185.25. 500ft CAT6 cable: $67.99. RJ45 connectors: $7.23. Total: $707.42
So it's actually cheaper to run it over SDI cable. Assuming you have cable crimping tools for RG59, that is.
Edward Carlson is offline   Reply With Quote
Old March 19th, 2016, 06:32 PM   #5
We actually already have HDMI to HDSDI converter boxes, and we have some 1505A and connectors from another install in our basketball arena...
This sounds like a very reasonable possibility. All I would need is the DA.
