Filming for US client, pal/ntsc playback issues?
So I have a wedding coming up in Belgium but the couple live and work in New York, they are going to get dvd's, a blu-ray and the HD files on a usb stick.
I edit everything in a 25p timeline and export as a 1080p 25p file, I then load that file into tmpgenc authoring works to make my dvd and bluray, will they play fine on their dvd and blu-ray player in the US? Same for my hd files on a usb stick, they are 25p, is the standard not 30 or 60p where they live and will my files cause playback problems? |
Re: Filming for US client, pal/ntsc playback issues?
NTSC is 23.97fps, 60i ( 29.94 fps timecode there are still 59.97 individual images(fields) just like 60P ) or 60P doesn't matter whether it is SD or HD and most North American DVD's ( US and Canada ) will not play PAL at all. So 25P PAL is a no go. Refresh rate for computers is mainly 60hz too. 30P is not a broadcast or disc standard but will of course play on the computer or 60P file will play fine but other rates may cause some issues depending on the software player. They may choose to get a multi-standard BLuray player like I have that will play anything.
Ugh, that doesn't sound promising, in tmpgenc I can select the outputformat as ntsc but I don't now what consequences that might have if the source material is pal.
Would it be a issue if I shoot, edit and export everything in 24p and then make a ntcs dvd and blu-ray out of that out of that and supply them with a 24p HD mp4 file? I need the files to be compatible for playback in Belgium as well. |
Also remember, DVD region is different between the two countries. US/Canada is Region 1. Western Europe is Region 2. Make sure you burn them with the right region, or they won't be able to play them back in the US.
#5 | |
#6 |
My panasonic g80 and gx85 have 4k 24p, my ax100 and GH4 don't, my ls300 however makes a difference and can shoot C4K in either 23,98 or 24p.
Would shooting in 24P only cause any playback issues? |
#7 |
I just recorded a small part with my g80 at 24fps and mediainfo tells me the file is at 23.976 (24000/1001)fps so I guess that should should be fine.
#8 |
DVD is the problem, isn't it. Everything else now is pretty much worldwide playback. However, in Encore, that I use, there are presets for the usual SD DVD formats. Personally, I now shoot for HD, and as I'm in the UK it will be 25 or 50 - usually 25p. Encore seems quite happy converting this to any format. You get the usual jitter on fast moving things as it duplicates frames to create the extra ones required for 30(29.97) on the DVD for NTSC. I usually warn clients who want 'foreign' formats that the DVD will playback in the US, but due to their TV standard, the quality will be slightly lower than the full HD version supplied on card/stick etc.
#9 | |
#10 |
I think that should work for you then. I know you edit with EDIUS so there is the correct preset for 23.97 there for the timeline.
#11 |
Just shoot and edit at 30. You will find that most if not all PAL DVDs will play it back just fine. Try a test one yourself and see.
#12 |
But how about when I burn that onto blu-ray? Won't that cause any playback issue in pal vs ntsc country?
#13 |
Doing a google I found this.
There are no "PAL" or "NTSC" Blu-Rays. They are all encoded to the new standard that doesn't require any legacy information. I have yet to see a new release that wasn't 1080p. |
#14 |
DVD burned in Encore etc usually default to Region 0 i.e. they will play in a player from any region.
#15 |
The difference between 24fps & 25fps is only 4%. When Hollywood movies are converted for release on DVD in Europe they simply speed them up & nobody notices.
