Duplicating an audio channel at DVinfo.net
Old October 29th, 2007, 01:05 PM   #1
I have a clip that uses only the left channel of audio, is there anyway to duplicate it to the right channel? The theater that is showing the documentary has a not so advanced audio system, and with that clip there is no audio.
Travis Johnson is offline   Reply With Quote
Old October 29th, 2007, 01:28 PM   #2
Right-click and select "Channels - Left only".
This way it's mono and you won't have any compatibility problems.
Old October 29th, 2007, 06:58 PM   #3
Thanks for the reply, actually I figured it out. You right click on the audio->select Channel and choose Combine.
Old October 29th, 2007, 07:55 PM   #4
Sponsor: JET DV
Travis, you're better off with "Left Only". With "Combine", if there's any noise at all on the right track, it will also be included.
Edward Troxel is offline   Reply
