PAL and crossfade numbers... at DVinfo.net
Old December 12th, 2007, 12:59 PM   #1
I work in PAL, so why when I do a cross fade, do the numbers run up to 29 before going over to seconds? Shouldn't they only run up to 24?
Renton Maclachlan is offline   Reply With Quote
Old December 12th, 2007, 04:31 PM   #2
Hi Renton
I don't have Vegas on the computer I'm working on at the moment - but could it be anything to do with the timeline settings - I think it's a tab in the project properties somehwere?
Ian
Ian Briscoe is offline   Reply With Quote
Old December 13th, 2007, 12:32 AM   #3
Just right click on the timeline and there are a LOAD of choices. Strange though, I would have thought this would have changed to match the project properties?
Alastair Brown is offline   Reply With Quote
Old December 13th, 2007, 03:21 AM   #4
So would I. Not sure what LOAD of options you are referring to.
Old December 13th, 2007, 03:53 PM   #5
Renton, right click with the cursor actually on the timeline numbers (see picture).
You'll find Alastair's 'LOADS' there! I guess you'd probably want Time & Frames or maybe SMPTE EBU.
Certainly when I just tried it the frame numbering *does* change if you change the projects properties from, say, NTSC to PAL. Perhaps it defaults to last used setting? Yeah, it does, just checked.
Cheers,
Ian . . .
Ian Stark is offline   Reply With Quote
Old December 13th, 2007, 11:24 PM   #6
Thanks Ian, I got it to change after your explanation...
Old December 14th, 2007, 02:28 AM   #7
Any time.
Looking at the NTSC options I am SO happy we're in PAL land!
