HDV down conversion... at DVinfo.net
Old January 3rd, 2008, 08:00 AM   #1
Hi,
Sorry if this has been covered before - I have searched - and also that it feels like a really basic topic!
I have ben recording in 1080-50i (PAL). I have some captured footage that someone wants to edit. Their editing software cant deal with HDV footage so Im trying to down convert in Vegas Pro 8.0a.
The problem i have is that the rendered file always appears stretched on the vertical... To me its seems that 1440x1080 doesnt go into 720x576.
So what 'project' settings should I use and what 'render as' settings.
Ive tried PAL DV widescreen for both and the output always appears vertically stretched...
Brendan Pyatt is offline   Reply With Quote
Old January 3rd, 2008, 08:13 AM   #2
ok well i tried changing the 'render as' file type previously i was using *.avi however if i choose mpeg2 and DVD PAL i get no stretching.
why is this ?
and further to this what format should use to an output that is as close (as raw) as the orginal but SD not HD.
Old January 3rd, 2008, 08:30 AM   #3
wow im confused! but possibly getting somewhere.
it seems that the *.avi is fine if i open it in vegas it only appears vertically stretched in the software video player i am using (GOM player). i also note that the *.avi looks much better and the file is four times the size of the *.mepg2.
from this i conclude that i should down convert to *.avi file format and not worry that it looks vertically stretched in a player as it looks fine in an editor.
i would love to know why?
thanks.
Old January 3rd, 2008, 03:23 PM   #4
HDV to SD by recording preview...
I have been told to downconvert by recording the preview output.
So i hooked my cam by ilink but what ever project settings or preview device settings i am always getting a jerky recording.
The hdv clip was captured using neohd (cineform) its properties are: 25fps 1440x1080x24
I set the project to PAL DV widescreen. Dropped the clip into the timeline.
Preview quality is Best(full). The preview device properties are: PAL DV widescreen.
But the recording is jerky...
Im sure it must be easy to convert a capture hdv file and save it on tape but i can't work it out!
- how do you delete a thread on here?
Old January 3rd, 2008, 03:32 PM   #5
Sponsor: JET DV
Previews may not be full framerate (hence your "jerky" output).
Instead, try Tools - Print Video to DV Tape.
However, that will simply do what you could do manually instead: File - Render As and pick the proper format for rendering.
Old January 3rd, 2008, 03:46 PM   #6
How would i save (record) a rendered file to a tape using a camcorder? this is exactly what i would like to do as i have this clip rendered in PAL DV.
thank you (very much!)
Old January 3rd, 2008, 03:58 PM   #7
Sponsor: JET DV
Put the rendered file on a timeline. Go to Tools. Select Print to DV Tape. Follow the prompts.
Old January 4th, 2008, 07:37 AM   #8
thanks again edward. your advice really helped !
