Date/Time Stamp in Media Manager at DVinfo.net
Old January 5th, 2008, 12:17 AM   #1
I'm using Vegas 8.0a (Build 179)
Is there a way to get the Date/Time Stamp field to show in the Media Manager view of clips? I see it in the Project media window but I can't find the field to add to the Media Manager window.
I really want this field exposed in the media manager so I can properly sort and tag my clips.
Thank you very much to whomever can answer!
Jim
Jim Vetter is offline   Reply With Quote
Old January 6th, 2008, 09:06 AM   #2
Old Boot
Hi Jim,
Interesting.
1] Date/Time Stamp appears within Project Media
2] The Date/Time Stamp information appears as "Recorded" information within Event Properties GENERAL
3] In Media Manager neither "Recorded" nor "Time/Stamp" make an appearance
4] However, there IS the "Original" date, but this reflects the actual date that the Media was placed on my hard drives.
5] I have a "Tape Name" filled within Project Media, when I ADD this as a column the column is not filled.
6] When I add a column "Timecode In" it gets filled
7] When I add a column "Timecode Out" it gets filled
8] When I add a column "Duration" it gets filled
9] I have EVEN manually ADDED my own Time/Date Stamp column - yes you CAN do this - it does NOT get filled.
10] Also from within: Event > Properties > General
a) Tape Name is there
b) Recorded is there
BUT ..
c) The Event is not Tagged, but it is! I can demonstrate this.
To me this implies some need for clarification. I read your same post on the "other" forum and your question remains sticking in my mind.
Grazie
Old January 6th, 2008, 03:58 PM   #3
clarification - specifically in MEDIA MANAGER i want to see the date / time stamp so i can search on it and select clips recorded at specific times for tagging and adding to project.
thanks!
Old January 6th, 2008, 05:07 PM   #4
Old Boot
thanks!
Yes, I know that . .. I mean seeking THIS from Sony. Larf!
Grazie
Graham Bernard is offline   Reply
