Vegas 8 Upgrade Path at DVinfo.net
Old January 15th, 2008, 08:00 AM   #1
Hi guys, question.
B&H has the option of buying Vegas 6 - after which you can install Vegas 8 upgrade - and it costs about 179 - Old story I know.
I am running Vista 64bit and the Vegas 8 Trial runs great. I've also heard many others running Vista 64tbit and 8a and say it runs perfectly good.
However, does Vegas 6 install ok on Vista 64bit?
If not - then it renders the above upgrade path null.
Please advise
Thanks for your help
Paul
Paul Dhadialla is offline   Reply With Quote
Old January 15th, 2008, 08:24 AM   #2
Sponsor: JET DV
I can say that Vista in any form is not supported by Vegas 6. Whether or not you can get enough of an installation to work for the B&H update, I don't know.
Old January 15th, 2008, 10:45 AM   #3
Originally Posted by Paul Dhadialla View Post
However, does Vegas 6 install ok on Vista 64bit? If not - then it renders the above upgrade path null.
Why? All you need is a valid serial number from a qualifying product to get the 8.0 upgrade. That's what I did. Purchased 6.0 with electronic download. Never even bothered to download it!
John Miller is offline   Reply With Quote
Old January 15th, 2008, 10:52 AM   #4
Sponsor: JET DV
Apparently the B&H upgrade is different and requires Vegas 6 to be installed when Vegas 8 is installed. If this hadn't been discussed elsewhere, I would completely agree with you.
Old January 15th, 2008, 11:13 AM   #5
Thanks Edward and John !
I've heard about the mandatory installation issue as well. That was my concern. I have FCP too - and back when i had express for example - all i needed was the serial - only makes sense. There is no guarantee that an old product will install on a newer OS
If anyone else has been able to install the B&H upgrade with serial only - please advise.
Thanks all
Paul
Old January 15th, 2008, 01:29 PM   #6
Correction: I bought Movie Studio - not Vegas 6.0 - directly from Sony as per this post:
http://www.dvinfo.net/conf/showpost....3&postcount=29
Sorry.
Old January 15th, 2008, 02:03 PM   #7
What about Vegas 7 owners? I have Vegas 7, but I'm planning on getting a new PC which most likely will be running Vista Home Premium. From what I understand, Vegas 7 doesn't work on a Vista PC.
Frank Genus is offline   Reply With Quote
Old January 15th, 2008, 02:25 PM   #8
Sponsor: JET DV
Frank, just order the upgrade direct for Vegas Pro 8 direct from Sony and there will be no issues whatsoever.
Old January 15th, 2008, 02:38 PM   #9
Thanks Ed, the issue however is that the upgrade via Sony's website is $249.99. That's a pretty big difference in price.
Old January 15th, 2008, 03:04 PM   #10
Sponsor: JET DV
I believe the B&H version will upgrade any version but you have to get the previous version installed. Sony support and/or B&H should really be able to help with these questions.
Old January 16th, 2008, 03:36 PM   #11
I concur with Ed, that while the special low priced BH V8 upgrade disc will not install by itself without 6 already installed, Vegas tech support can bypass the issue. By verifying your V6 serial # over the phone, they can get you on your way by issuing you a replacement serial number to activate a V8 downloadable from their website, replacing the physical BH upgrade you've bought.
They worked out a similar arrangement for me.
Sam Houchins II is offline   Reply With Quote
Old January 18th, 2008, 08:53 AM   #12
Sam,
Thanks for the tip. Glad i stumbled across this post. I picked up mine from the postie today and will install tomorrow so i'm hopeing i can now do it with out wasting twice the time and adding more bugs to windows and saving an install. :)
Welcome... to the real world!
Daymon Hoffman is offline   Reply
