Preview via Windows Secondary Display at DVinfo.net
Old March 7th, 2008, 03:02 AM   #1
Preview via Windows Secondary Display.
Is there any trick to doing this or is it what i'm doing.
Set up, extend windows onto second display, then grab the preview window and drag to second display, resize to what size i want?
Is this it?
I thought that the Video preview window would resize to the second display ?a bit like firewire out to camera to TV,LCD screen?
Any thoughts on this.
Cheers
Simon
Old March 7th, 2008, 03:21 AM   #2
Images: 32
Nope that's not it. You're just spreading Vegas across two monitors.
Look for an icon on the Video Preview window that looks like a small monitor, that's the toggle for Preview on External Monitor (Alt+Shift+4). You can make sure you've setup your Secondary monitor settings correctly in: Options - Preferences - Preview Device.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old March 7th, 2008, 09:57 AM   #3
For the last couple years i have been using firewire out to preview footage but i thought i'll try Windows Secondary Display.
What am i doing so wrong that i cant get it to work? i feel like such a gooball.
Simon
Old March 7th, 2008, 10:05 AM   #4
2 monitors with Vegas
Maybe something in this thread will help you work it out? Good luck!
http://www.dvinfo.net/conf/showthread.php?t=115421
Old March 7th, 2008, 04:27 PM   #5
Thanks Andy,
Will try it again but for some reason it's a no go, somewhere along the chain it aint working like it should.
Simon
Old March 7th, 2008, 05:50 PM   #6
I can get windows onto the other screen but not the preview window, second display seems to flicker when i play the time line.
any ideas/
Simon
Old March 7th, 2008, 09:09 PM   #7
Ok i have found the problem.
I thought i would check an update with new drivers as my video card is an old Radeon 9600 series. Downloaded new drivers and now it's working.
Thanks to all that have helped me.
Cheers
Simon
Old March 8th, 2008, 10:23 AM   #8
Images: 32
Just for the record, I had to do the same with my NVIDIA drivers. Used to be a bit of a hassle because I would changed my secondary display monitor a lot (firewire then vga monitor and back again). After the latest NVIDIA update the system is rock solid even switching mid-stream.
