HVX slomo blues at DVinfo.net
Old March 9th, 2008, 01:33 AM   #1
HVX slomo blues
Hi all,
I shot a 50p clip with the intention of overcranking. The problem I'm having with the footage is that I didn't shoot it in 25pn, so it's not automatically playing those 50 frames over 2 seconds. When I put the clip on a 25p timeline and set a velocity envelope to 50%, every 2nd frame is duplicated. That confused me, so I changed the timeline to 50p - again every 2nd frame was a duplicate. I converted to avi with cineform to bring into Vegas.
Any thoughts on what I'm doing wrong and if there's a solution?
Steve Madsen is offline   Reply With Quote
Old March 9th, 2008, 10:46 AM   #2
CTO, CineForm Inc.
It is acting like you don't have 50p source. If you are sure you have 50p sources, you convert again in HDLink and set the frame rate change to "-50%" -- the control is listed as "60p to 30p", but that will also convert 50p to 25p.
Old March 11th, 2008, 05:32 PM   #3
Thanks David.
Yep, definately a 50p clip (properties everywhere confirm this). I tried your trick, same stuttery result. Very confusing. If it was a 25 frame clip, I would have expected Vegas to have combined frames to make the in between frame (technical jargon :)), instead its displaying a duplicate frame. Oh well, look like I'll have to move on.
