Vegas 8 - an unmitigated disaster !! - Page 3 at DVinfo.net
Old April 23rd, 2008, 06:09 AM   #31
You might try taking out 2 gigs of memory and running it, then try the other two gigs, or even try running just 1 at a time if you don't need to run it in pairs (don't remember what kind of memory your running or if you even mentioned that). That would be a quick and dirty way of tracking down bad sticks.
Old May 1st, 2008, 11:39 AM   #32
Sorry I missed your response...
memtest86+ is an ISO image that you burn to CDROM and boot the machine off of. You don't run it out of windows... be sure to read the instructions :)
If you can't get memtest working, I'd try removing a pair of memory modules to see if that helps (or at least changes the situation). Juggle them around until you find an arrangement that works.
Definitely have some hardware demons causing your headache's!
Andy Mace is offline   Reply With Quote
Old May 4th, 2008, 01:04 AM   #33
last year I had a really bad time with my home build computer locking up and it kept on looking like memory issues. I finally painfully traced it down to the BIOS reading the wrong latency settings off of the RAM; I checked the proper settings online, reset the latency to what the ram should have been running at and haven't had a crash since. Very cheap fix.
Ken Steadman is offline   Reply With Quote
Old May 4th, 2008, 12:46 PM   #34
Originally Posted by Ron Cooper View Post
As this latest saga has happened with out any programs running it is becoming more obvious that the issues are PC related.
Ron.
It's too bad that you can't change the title of this thread, since it appears that Vegas 8 is NOT an "unmitigated disaster."
John Cline is offline   Reply With Quote
Old May 4th, 2008, 12:53 PM   #35
I agree John. However anyone reading the thread in it's entirety will see how the process goes so often when tracking down problems.
Old May 4th, 2008, 05:35 PM   #36
Just skimmed the thread and thought I would chime in:
I had endless crashes with Vegas 7e, 8a and 8b that I tracked down to two separate problems. Now after fixing these, everything is quite stable. Just in case your problems are similar to what mine where here are the two issues I corrected:
1/ Cineform Neo HDV installs a driver called "AJACaptureFilter.ax" which apparently is prone to crashing Vegas if you don't have the AJA card installed. Just do a search for "AJACaptureFilter.ax" and delete it. Unless you have this card you don't need it. This fixed the constant crashing I was getting when I used Cineform NeoHDV clips.
2/ I started to turn off my Virus protection program every time I capture HDV video. It seems that my constant crashing with native m2t clips was due to errors that were introduced (but not reported) when I captured with either HDVSplit or Vegas's capture utility. Since no dropped frames were reported I thought that the captures had been fine. They weren't. There were some kind of formatting errors that were embedded in my m2t clips that would make them crash Vegas. Since I started disabling my virus protection during capture, I have done maybe seven or eight tapes that have given me no problems whatsoever.
Vegas has been working perfectly lately for me, but I can really feel for you. Until I worked through these two issues, the phrase "unmitigated disaster" sounds like a pretty accurate description of my experience.
Laurence Kingston is offline   Reply With Quote
Old May 13th, 2008, 05:10 PM   #37
Vegas8 and EX1 files
I upgraded to Vegas 8 mainly so I would have a second machine to edit
EX1 files. but I still have not been able to get the XDCAM utility in the editor to work. I read something about converting the files to some other file format MXF?
SO if anyone has any wisdom I would love to have it.
Other wise I am stuck with FCP.
Ed
Ed Mellnik
EMA Video, Portland Oregon
Ed Mellnik is offline   Reply With Quote
Old May 13th, 2008, 07:07 PM   #38
Ed Mellnick, what a blast from the past. We worked on a project in... 1985? (I was at Creative Media, you were downstairs on NW Kearney(?)
Do a little search of the forum, lots of good info on EX1 and Vegas Pro8. This has worked for others, it should work for you. Sorry I can't help directly, I've not shot with the EX1 yet.
You'll want to look at this:
http://www.dvinfo.net/conf/showthread.php?t=108339
And this:
http://www.sundancemediagroup.com/ar...ony_Vegas8.htm
Seth Bloombaum is offline   Reply
