Using DVDA to burn Video_TS file. at DVinfo.net
Old June 16th, 2008, 06:40 PM   #1
I have a Video_TS file, that didn't come from Vegas or authored by DVDA. Is there any way I can use DVDA as a burning software to put that file on a blank DVD?
Norris Combs is offline   Reply With Quote
Old June 16th, 2008, 09:35 PM   #2
Nero might do it, but what I would do is bring the file into Vegas and render it out like you would any project, than take the rendered file to DVDA.
Old June 17th, 2008, 06:34 AM   #3
Sponsor: JET DV
Put that Video_TS folder in another folder all by itself. Now add an empty "Audio_TS" folder so you'll have both.
Open DVD Architect and tell it to Burn. When the options come up, tell it to burn and choose "Previously prepared folder" and point it to the the folder containing the Video_TS and Audio_TS folders. It should then burn the DVD just fine.
Old June 17th, 2008, 07:11 AM   #4
Cool, thanks Edward. Another piece of info to add to the arsenal!
Old June 17th, 2008, 08:45 AM   #5
Thanks guys,
In fact I had been using Nero, but it started developing problems. Before I had time to read your answers, I got AVSMedia trial download, works great btw.
Old June 17th, 2008, 08:49 AM   #6
Glad you found a solution. Thanks for the tip on AVS Media.
Old June 17th, 2008, 09:39 AM   #7
Would this also work if it was an ISO file?
Old June 17th, 2008, 10:23 AM   #8
Sponsor: JET DV
I'm not sure - I've always just created the folders. Give it a try and let is know! Nero should definitely do the ISO, though.
Old June 17th, 2008, 11:32 AM   #9
Yep, Nero does the ISO burn just fine.
