Logging HDV footage with Vegas at DVinfo.net
Old June 25th, 2008, 01:11 PM   #1
Is there a way to log HDV footage like you can when you capture SD in Vegas? I really like that but the HD capture interface is different than the SD. I find being able to log scenes and in and out points to be a great help.
Old June 26th, 2008, 06:14 AM   #2
Sponsor: JET DV
Batch capture of sections in HDV can't currently be done. You could just capture the whole tape and then break it up using Sub-Clips.
Old June 26th, 2008, 12:15 PM   #3
Thanks Edward,
Is there any tool that will allow me to log HDV tapes? I use to preview all footage and log scenes. Then I could just capture only the scenes I thought I needed and if I found I needed other I could go back and quickly capture just those scenes.
I thought I read somewhere that this may not be possible with HDV because of the fact that it records GOP's and not discrete frames.
Old June 26th, 2008, 01:22 PM   #4
Sponsor: JET DV
I don't know of anything that will batch capture HDV.
Edward Troxel is offline   Reply
