Getting good video out of Vegas at DVinfo.net
Old July 17th, 2008, 01:33 PM   #1
The one thing that's really bugging me: How do I get good mp4 video out of Vegas. I can edit just fine, but rendering and exporting almost always trips me up.
The biggest problem seems to be that the framerate seems to be very low - as if the timeline is only 15fps or so.
How do you get good video out of Vegas? Should I try exporting to Mpeg2 and using a third-party utility to do the conversion?
Edit: The timeline IS only 15fps! No wonder! I don't know what setting I have in there that's causing it to export to 15FPS though.
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1
Brian Boyko is offline   Reply With Quote
Old July 17th, 2008, 02:26 PM   #2
real simple, I use vegas to render into mpg 4 at 3 mbps progressive, I shoot with a V1, 1080i and capture with cineform which deinterlaces and I edit progressive. I use mpeg4 at 3 mbps cbr, and wmv hdv at 3 mbps,
http://www.vimeo.com/1358671 is a wmv clip
http://www.hughmobley.com/arboretum.html is a mpeg 4
take a look
Hugh Mobley is offline   Reply With Quote
Old July 17th, 2008, 09:41 PM   #3
Images: 32
The main settings recommended by Vimeo:
1. H.264 - use the MainConcept AVC/AAC or Sony AVC encoder in Vegas
2. 1280x720 - set as a Custom Frame Size
3. 3000-5000 kbits/sec - bit rate in Vegas will show as 3,000,000-5,000,000 bps
4. AAC 128kpbs stereo - 48,000 Hz, 128,000 bps
Personally, I like to use 2-pass VBR it takes a little longer, but I like the results, plus the files are smaller than CBR.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply
