changing bit rates at DVinfo.net
Old July 27th, 2008, 04:35 PM   #1
changing bit rates
I've used a bit rate calculator to find the proper rate so when Orender my video it will fit on a dvd, but for some reason it won't let me change it in the render as options. when i'm in the options i go to custom, and try changing the system bit rate but it keeps changing it to the value that was already in there. am i trying to change the wrong variable, or is there somewhere else that i change the bit rate?
Tyler Anderson is offline   Reply With Quote
Old July 27th, 2008, 05:22 PM   #2
Are you saving the template after the changes have been made ?
Paul.
Round 2
GH5,FZ2000
Old July 27th, 2008, 05:41 PM   #3
whenever i click off the tab for the system bit rate it goes back to the original number that was there before
Old July 27th, 2008, 05:43 PM   #4
Don't change in SYSTEMS -after setting up the clips and you're ready to go goto FILE>RENDER AS>(choose MPG2)>CUSTOM>VIDEO>then set you're bitrates and save as (name it here and use the disc icon to save)
The preset will be there until you delete it.
Don
Don Bloom is offline   Reply
