Adding a color curve to the WHOLE project - Page 2 at DVinfo.net
Old September 7th, 2008, 05:46 PM   #16
Originally Posted by Edward Troxel View Post
File - Render As - and pick the cineform/HDV codec.
Is that something you have to buy because I don't see that under "save as type". I use 8.0b.
Oliver Darden is offline   Reply With Quote
Old September 7th, 2008, 07:03 PM   #17
Images: 32
1. In the Render As window select: Video for Windows (*.avi)
2. Then select one of the HDV intermediate templates
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old September 7th, 2008, 07:05 PM   #18
Images: 32
If you want to use QuickTime, you'll have to customize one of the templates, specifically change the Video Format.
Old September 7th, 2008, 07:07 PM   #19
I see...thank you. Which one should I use, HDV 720-30p or HDV 720-25p?
I am editing SD 720 x 480 footage.
Old September 8th, 2008, 07:26 AM   #20
Sponsor: JET DV
Since you're in the US, use 30p. 25p would be for PAL countries.
Old September 8th, 2008, 09:51 AM   #21
ok, and my final question on this subject.
This format is better than rendering to uncompressed avi correct?
I will be rendering all 23 scenes to this and then opening them all in 1 project and rendering to mpeg2 / ac3 for a final DVD.
I will also be printing to tape from this format.
Old September 8th, 2008, 10:20 AM   #22
uncompressed files are HUGH! No real reason to render to uncompressed unless you need to save an alpha channel or something that requires you to do so.
Don
Old September 8th, 2008, 01:25 PM   #23
Wait... using a nested project "rerenders" the file?
I thought it just opened it in the timeline as one track for convinience... exactly what the OP is trying to accomplish.
Kevin Richard is offline   Reply With Quote
Old September 8th, 2008, 02:08 PM   #24
I agree with your assessment. There is no rendering going on when you drop a project on to a new time line. There may be some formatting issues to preview, if the projects are not the same. I do believe use of the project files can subject the final compile project to potential issues or errors, that are unnecessary risks, so once I am ready to lock a scene, I lock it by rendering, and use that in my final compile project. As I said, I elect to keep it simple.
Chris J. Barcellos
Old September 8th, 2008, 04:25 PM   #25
I'm with you on that... just wanted to make sure that the facts were straight for me as well as anyone else that might be reading this.
So to the OP you could just drop your files in via nested and accomplish a lot of what you are looking to do. You would even be able to color correct different scenes differently if you wanted to as they would act like seperate clips on the "master" timeline.
Old September 8th, 2008, 04:28 PM   #26
The reason we are not talking about nested projects is becuase it not working for me (and a lot of other people) so I am trying to find another way of working neatly with a lot of scenes.
The cineform seems to be working for me while keep it high quality with out too much compression, I like the idea of rendering each scene and then taking it into a single project for the final render. This way also takes a lot of the stress off Vegas by pre-rendering big projects. This way I CAN use HUGE jpeg files and Vegas wont crash.
Really this thread was about something else to start with and kind of went off in another direction but it really helped me out...sorry if there is some confusion.
Old September 8th, 2008, 04:49 PM   #27
I also vote as someone else did to just render out SD to regular dv codec... you don't lose too much, but I've never compared to cineform so I really can't comment.
Old September 8th, 2008, 05:08 PM   #28
What do you personally render out to for something like this Kevin?
Old September 8th, 2008, 05:12 PM   #29
I've just come back out to regular a DV NTSC file. Only done once because I needed to quickly render out some clips for a live show that was then add them later to a dvd as a bonus.
"School of Rock" band camp thing for kids.
