Does anyone have a small video clip of just what can be achieved with vegas ? at DVinfo.net
Old September 7th, 2008, 11:10 AM   #1
Does anyone have a clip of there work showing the effects you have achieved using vegas suite ?
Thanks in advance.
Jayson Corcoran is offline   Reply With Quote
Old September 7th, 2008, 11:53 AM   #2
Slash Rules!
I'm not sure exactly what you mean, but every aspect of these shorts was accomplished in Vegas:
http://joshbass.com/Site/Short_Films...armclock_1.wmv
http://joshbass.com/Site/Short_Films...rine_wm9_1.wmv
It's pretty powerful, way more versatile than it might first appear.
Old September 7th, 2008, 12:20 PM   #3
Hi Jayson,
There are a few examples of some effects in use in a short teaser clip on my business home page vIT using bump maps to add lighting effects, colouration, various transitions, light rays, pan & crop, etc. . There are a couple of other clips dotted around the site as well, all created in Vegas.
Here's a short piece I have just finished for a client in which I have used some effects (glow, blur, cookie cutter, some 3d, various transistions), again all done in Vegas (but I did use MB Looks as well, which is a Vegas plugin but not part of the Vegas suite) http://www.videoit.uk.com/client_vid..._v502avnet.wmv
And for extreme effects use you could look at YouTube - 'Spaceship' by Craydle
Should give you an idea of some of the things you can do. I have no doubt that there are far better clips that others can show you!
Ian . . .
btw, I love Josh's Blisterine!
Ian Stark is offline   Reply With Quote
Old September 8th, 2008, 07:48 AM   #4
Here's my two cents - a heavily effected short clip as a band promo.
Bmmchk Live Performance on Vimeo
In addition to the plugins that are included with Vegas Pro 8 I also use Boris FX and Magic Bullet Looks. However roughly 75% of what was done in this clip is all straight from Vegas. Most of the effects are keyframed.
James Hooey is offline   Reply With Quote
Old September 8th, 2008, 11:10 AM   #5
This is EXACTLY what I was after, showing samples of alteration outside of the fottage taken, thats made my mind up, im off to buy vegas now :)
Old September 8th, 2008, 10:33 PM   #6
>Blush<
Sounds like you liked the possibilities.
Believe me, it's the tip of the iceberg compared to some work I have seen using Vegas. With time and patience you can achieve even far more advanced effects.
All the best.
Old September 9th, 2008, 02:29 AM   #7
I downloaded the trial version of vegar, around 20 minutes after buying the full version but it seems many features are not active, is this the case ?
Old September 9th, 2008, 06:45 AM   #8
To clarify, which version did you download and/or buy? There are four different versions of Vegas. I have only ever used the professional versions, most currently Vegas Pro 8. As well I will mention that I have added plugins that do not come with Vegas Pro 8 as already mentioned (Boris FX, Magic Bullet Looks 1.1).
To clarify further, what features are not active?
Old September 9th, 2008, 06:55 AM   #9
I downloaded Pro-8, this is the same that I also purchased.
It just seems that many icons are not lit when I open the software, I would say maybe 25% are lit, the rest are greyed out.
Old September 9th, 2008, 07:28 AM   #10
Sponsor: JET DV
Well, you would have to clarify some more. Some may appear "greyed out" because they're currently turned off. Others may be "greyed out" because they're not currently usable given what you have selected/on the timeline. For example "delete track" would not be a valid option if there were not tracks so it would be "grayed out".
If you have Vegas Pro 8, rest assured that you have ALL the features.
Edward Troxel is offline   Reply
