vegas randomly says my files are broken at DVinfo.net
Old September 26th, 2008, 05:01 PM   #1
Hi
im trying to edit a bunch of 720p h.264 clips from a sanyo HD1000, and sometimes when i import a bunch of files into project media it will randomly tell me that "an error occured opening the media file". i then get to either select a replacement media file or flag it as offline. if i select an alternate file and pick the same file again, then its all good.
Olas Polare is offline   Reply With Quote
Old September 27th, 2008, 12:12 PM   #2
Sounds interesting. I had this in different way sometimes during editing HDV footage. Sometimes a clip produces black frames or red frames which resulted in black outs even during render. Restarting Vegas or just reopen the saved project removed them. I have no clue if this kind of failure is realy a failure or just sluggish programming. As long as you have a work around you are fine but check if this is giving you issues during render or later in the rendered video.
Axel, San Jose
Axel Scheffler is offline   Reply With Quote
Old September 28th, 2008, 03:57 AM   #3
ive also noticed that every time i alt-tab to another program and back, vegas holds for a bit (to start looking if any of the material has changed?) and then sometimes it suddenly says my files arent working, tho they worked just a minute ago.
this is a complete showstopper for me
Old September 28th, 2008, 10:07 AM   #4
Originally Posted by Olas Polare View Post
...every time i alt-tab to another program and back, vegas holds for a bit...
Options > Prefs > Close media files when not the active application.
If it's de-selected, select it.
If it's selected, de-select it.
Mine is selected and I don't have this problem.
Old October 3rd, 2008, 01:46 AM   #5
hey i tried this, and i havent had any problems since!
that doesnt necessarily mean the problem is gone though as i havent done a lot since either, but lets hope!
another strange thing: i browse files in the explorer window, pick the one i want and go "open in trimmer", pick out the part i want and drag it on the timeline.
But after a while "open in trimmer" went gray and i couldnt open any clip i hadnt opened before. Restart vegas, and poof all files can now be opened in the trimmer.
Whats that all about?
