Render as Sony AVC, where's my audio gone ? at DVinfo.net
Old September 28th, 2008, 07:21 AM   #1
I've been rendering some footage with my "vimeo" template, the sony AVC template, the same template that i've always used as per vimeo recommendation but when the render is complete i now have no audio in the rendered file.
In the template the "include audio" is ticked, i even dragged the rendered file back into the vegas timeline so that i could "see" the audio peaks, there aren't any.
Does anyone have any advice ?
I prefer (used to) the sony AVC rather than the mainconcept mp4 because the sony template renders a lot faster than the mainconcept template.
The only clue i've got is that this is the first sony AVC render i've done since installing the pro 8 (c) update.
The other render templates work ok.
Paul.
Round 2
GH5,FZ2000
Old September 28th, 2008, 08:54 AM   #2
I don't use this particular format so I tried a few test renders on 8.0c using DV, HDV & AVCHD footage.
All completed renders included audio.
If it matters, I'm using the latest QuickTime player (7.5.5).
Old September 28th, 2008, 05:47 PM   #3
May I assume you checked the include audio box in the audio tab ?
Chris J. Barcellos
Old September 28th, 2008, 08:39 PM   #4
Sponsor: JET DV
Well in the original post he did say:
Is the audio heard when playing back the timeline? (just want to make sure it's not muted or something). Maybe change the audio settings in the template to something different and see if that helps? For example, maybe from 48 to 44.1?
Old September 29th, 2008, 03:27 AM   #5
Yes the audio is there when playing back before render, after render though, no audio.
I even dragged the rendered clip back into the vegas timeline, the audio track is there but no audio peaks, just the flat line.
Weird. It's the same "vimeo" template i've been using since i started using vimeo, first time i've used this template since installing update (c).
I get the same results though, same file size, same picture quality, only sony avc renders from mxf to mp4 with recommended vimeo template in about 3x and main concept takes about 8x.
Paul
Round 2
GH5,FZ2000
Old September 29th, 2008, 07:50 AM   #6
I'm not in front of my PC right now, but I think if you change it from .avc to .mp4, the "include audio" option should change on the audio tab. I'll try to check it when I get home.
HTH,
Chad
Chad Dyle is offline   Reply With Quote
Old September 29th, 2008, 08:52 AM   #7
Smart arse.
Changing to 44,100 worked, thanks Ed.
Strange how it worked before when i was on 8(b) though.
Never mind, fixed now.
Many thanks, to all, especially Edward.
Paul.
Round 2
GH5,FZ2000
Paul Kellett is offline   Reply
