Vegas crashing when closing my project? at DVinfo.net
Old November 20th, 2008, 07:16 PM   #1
I'm hoping to find out if this is a hardware or software issue ...
Yesterday I finished work on a compilation of 75 individual DV interview clips that I printed to tape using my Sony HVR-V1U. Each clip had been edited as a separate Vegas project; I simply imported the .veg files into my compilation, added text "slates" between them, and everything worked just fine. The total length of the project was 1 hour, 3 minutes. I discovered that my camera only records from Vegas in DVCAM mode, which eats a 63 minute tape in 42 minutes, so I had to split the project into 2 halves but other than that, no issues!
After printing the tapes, I closed the application and got a message "do you want to save changes to your project?" ... odd, because I'd saved everything before making the tape. I clicked "yes" and the program crashed. I also experienced a "hang" when restarting Vegas.
So I'm wondering, is this a memory or processing issue? Or did something get a little goofy in the project file? If anyone has some insight, please share - thanks!
Sam
Sam Renkin is offline   Reply With Quote
Old November 21st, 2008, 08:14 AM   #2
Sponsor: JET DV
By printing to tape, you *DID* change the project. I created "pre-render" files for all sections that needed rendering. Basically it was asking if you wanted to save those pre-renders. Don't know why it would crash after that but that's why it asked you to save.
Remember you also have the .veg.bak file you can try. Also, you can use my free Auto Save custom commmand (vegas pro 8 only)
Old November 21st, 2008, 06:44 PM   #3
Any chance you're running anti-virus?
Look at the Vegas project title when you're exiting; if you see an asterisk next to the name, you'll want to save.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline   Reply
