Rendering 720x486 without "uncompressed"? at DVinfo.net
Old May 13th, 2009, 08:31 PM   #1
Is there any way to render an AVI that is 720x486 WITHOUT using "uncompressed" video settings?
I have a project that is due for a widescreen shaped video wall that requires NTSC standard 720x486. I cannot find a setting in Vegas or Premiere Pro that allows me to merely render out a normal widescreen DV AVI but at 720x486. The only way to change it is to select "uncompressed" but that jacks the size of the 90 second video up to over 3.2 gigs. Is there no other way around it?
JR
Jeremiah Rickert is offline   Reply With Quote
Old May 14th, 2009, 12:30 AM   #2
JR
Are you saying that your standard "NTSC DV Widescreen" template doesn't render out at 720x486 Widescreen DV-AVI?
If that's not actually what you want, then hit the "Custom" button and alter to taste.
Edit... remembering to change the "Video format" drop-down to a suitable codec.
Andy Edmiston is offline   Reply With Quote
Old May 14th, 2009, 05:28 PM   #3
Yup.. "appropriate codec" is the stumper there. The video wall can't take most codecs. I was previously about to use cinepak, but I don't have that codec listed in Vegas anymore.
Old May 14th, 2009, 05:48 PM   #4
You can't render using the DV codec at 720x486. 720x480 NTSC and 720x576 PAL are the only valid sizes for DV. You can do MJPEG (Motion JPEG) at 720x486, although you would need to install an inexpensive ($30) MJPEG codec because it isn't native to Vegas. MJPEG is very good looking, highly configurable and pretty universal and I'm guessing it may be one of the codecs that the video wall can use.
Find out what codecs the video wall will take and we should be able to help you find a suitable codec in Vegas.
John Cline is offline   Reply
