Can't render .mp4 files at DVinfo.net
Old May 20th, 2009, 02:47 AM   #1
working with vegas 9 trial..so far I like it..the whole program is buggy..things crash for no reason..sometimes it says files are missing and they are not..it just freezes at random as well..this is for a new pc with i7 12 gig ram..
anyways the latest issue is that it wont render mp4 files..it either a)freezes of b) gives me some sort of error code...and just shuts down..
currently I am trying to render a video to post on vimeo..and for whatever reason its not moving..
anyone have any insight?
Peter Ferriero is offline   Reply With Quote
Old May 20th, 2009, 11:57 AM   #2
Not familiar with any particulars of v9 Pro trial version, but, in previous versions the mainconcept codecs aren't accessable until a licensed version of DVDA is installed. So, you might try the Sony MP4/AVC, or QT, or out to another MP4 encoder.
The QT MPEG4, at least, ought to be working in the trial version, since it depends on QT for the codec.
Old May 21st, 2009, 07:12 PM   #3
hey, I just noticed mine doesnt do mpg4 either.....weird.
Ian Planchon is offline   Reply With Quote
Old May 22nd, 2009, 06:12 AM   #4
same problem here w/ licensed version
wrote to sony: they said to set rendering threads to 1 and reinstall. still does not work.
Sony mp4 works fine but can not set for high profile, multi-pass and reference frames. So I output a Avid DnXHD and convert in Handbreak, it takes twice the time.
I put stuff on to You Tube and would like to duplicate the specs found here:
YouTube does 720P HD using H.264
Any suggestions would be appreciated.
Roy Feldman is offline   Reply With Quote
Old May 22nd, 2009, 07:27 AM   #5
It's been proven that doing a 2-pass encode with this codec will cause Vegas to instantly crash.
Thanks to posters on the Sony Vegas forum, SCS is aware of the problem.
Unfortunately there's no word as to if/when this bug will be fixed :-(
Old May 22nd, 2009, 08:42 AM   #6
Sorry, i cant help other than to say it does work. I use Sony AVC to convert my files for Vimeo and V9 renders .mp4's fine.
Not sure why you would want multi pass etc for Vimeo (but then i dont know much anyway ;-)
Dave.
Dave Pearce is offline   Reply With Quote
Old May 27th, 2009, 08:44 PM   #7
Dave,
I have Vegas 8 Pro and I haven't found Vimeo able to load .avc files. I see .mp4 for SD, but how do you get .avc or .mp4 HD files from Vegas for Vimeo.
I've been using .wmv, but my footage doesn't look as clear as others using H.264 or .mp4, so I'm assuming its a combination of the codec and Vimeo's compression being optimized for H.264. I'd like to create the best file possible for Vimeo to get sharper, smoother images.
Roger Shealy is offline   Reply With Quote
Old May 28th, 2009, 01:10 AM   #8
When you go in to the template (for example in my case the PAL 1920 x 1080 AVCHD) go to the System tab and change the output to .mp4.
That will then output a .mp4 file that Vimeo will accept. I guess as your not using PAL then you could satrt with the NTSC template. Once you do all this you can save the template for future use.
Based on the above template i will then go to the Video tab and change the frame size to custom and enter 1280x720, change the profile to main, filed order to None (progressive scan), leave the bit rate at 16,000000 although as i said i think this might be more than enough and of course slows rendering down so you can lower it.
Hope this helps.
Dave.
