Problem Starting Sony Vegas Movie Studio 9 at DVinfo.net
Old May 20th, 2009, 12:23 PM   #1
*Timeline*
I downloaded the trial version of Sony Vegas Movie Studio Platinum 9 to my computer. Worked great no problems.
After the trial ended I purchased a copy.
When installing the purchased copy I was instructed to first remove the trial version which I did. After the installation when I try to start the program I get the screen that says "your trial has ended would you like to purchase".
I uninstalled again as well as deleted the registry keys. I got the same message again after reinstalling and starting the program.
Has anyone seen this before and if so what can I do to remedy the situation?
Kevin
Kevin Crockett is offline   Reply With Quote
Old May 20th, 2009, 07:52 PM   #2
Sponsor: JET DV
So say "YES". Then enter the serial number you received! The trial and full products are exactly the same - except the trial expires. Now you need to say "YES" to purchasing. You have the necessary serial number so there will be no waiting!
Old May 21st, 2009, 11:28 AM   #3
Ed
Thanks. That did it.
Believe it or not I did do that but I always went to the web option which takes you to the shopping cart in the sony store.
This time I clicked on the phone option which tells you to phone in your order them input the serial number for activation.
Thanks Again,
Kevin
