MPG file is red in timeline and preview is blank at DVinfo.net
Old June 9th, 2009, 10:58 AM   #1
I just purchased a MPG video from the link below. When I drop it into the Vegas 8.0c timeline it appears red and the preview window shows nothing. There is also a blue line above the timeline for the duration of the clip. I can play the clips fine in WMP WMM. When I convert it to MOV and then bring it in it is ok. I thought Vegas supported the MPG format? Does anyone know what is happening?
Stock Footage of Cloudless earth on a white background. Seamlessly loops.
Thank you.
MPG file is red in timeline and preview is blank-vegas-red-clip-timeline.bmp
Last edited by Ken Olson; June 9th, 2009 at 12:47 PM. Reason: added screen shot & blue line
Ken Olson is offline   Reply With Quote
Old June 9th, 2009, 02:57 PM   #2
Sponsor: JET DV
The blue line is normal. If you do a manual ripple, that's how far things will ripple.
The red typically indicates a problem reading the file. Getting a black preview would seem to confirm that. You might try running it through a program like mpeg2repair or use some other program to convert it to a format that Vegas likes better.
Old June 9th, 2009, 06:35 PM   #3
this is one reason why you may find people less likely to purchase stock footage if it is only available as a MPEG. THe other reason is MPEG is a lossy compressed version of the MJPEG/MOV format. Since most people will be taking their footage and further compressing it, using footage that starts out heavily compressed is less desirable from a quality point of view.
Jason Robinson is offline   Reply With Quote
Old June 9th, 2009, 09:59 PM   #4
My recent experience with red clips is that the files were too large. I fixed one red clip problem by increasing the "Dynamic Ram Preview" in the preferences menu / video tab. This apparently allocates more RAM for use in Vegas.
Ryan Laytart is offline   Reply With Quote
Old June 9th, 2009, 10:10 PM   #5
The file is just under 6MB and the only one on the timeline.
Old June 15th, 2009, 01:26 PM   #6
As it turned out, the file was an MPEG-1, not MPEG-2. I guess Vegas doesn't support the MPEG-1 format?
I got the provider to send me the file in MOV format at no extra charge, which of course worked.
