2 hours for a 30 minute render? at DVinfo.net
Old June 19th, 2009, 09:49 AM   #1
rendering 720x480 vid VBR avg 6k rate, progressive, 4:3 aspect ration.
Last nite it took no more then 30 minutes, today its moving extra slow saying 3 hours at times. All 4 cores of CPU are working almost 80%...any ideas?
Martin Wiosna is offline   Reply With Quote
Old June 19th, 2009, 10:50 AM   #2
Check and make sure that you didn't accidentally bump the Level control in the Track header.
BTW, for anything less than a 70 min. program, I use a CBR of 8,000,000.
Old June 19th, 2009, 11:18 AM   #3
track header slider (i assume) is at 100%...
Old June 19th, 2009, 02:57 PM   #4
also check the clips themselves to make sure you didn't accidentally lower the level on one or more. I've done that in the past and felt quite sheepish later when I realized my error.
o | o
\__/
Don
Old June 20th, 2009, 02:01 PM   #5
still having the same issue....
Old June 21st, 2009, 09:41 PM   #6
Ok figured out my issue. I'm using a color correction AND NeatVideo for the entire clip. Just read today that NeatVideo is very processor intensive plugin.
For a test I rendered a 1 minute clip raw, in 16 seconds and with neatvideo and color correction at 16 seconds it was at 1%.
Guess you learn something new everyday.
Old June 21st, 2009, 10:38 PM   #7
I guess you do.
The other lesson learned from this is to give as much information as possible when you have a problem as it makes a diagnosis much easier.
Neat Video is well known as a processor hog.
Old June 22nd, 2009, 03:00 PM   #8
Magi Bullet is a hog also. I love the white diffusion filter but it takes forever to render.
Stan Harkleroad is offline   Reply With Quote
Old June 23rd, 2009, 08:37 AM   #9
It's a lot faster if you have the full version and use one of the recommended graphics cards.
Richard
Richard Hunter is offline   Reply
