working with m2t files at DVinfo.net
Old July 7th, 2009, 03:29 AM   #1
Hi guys, working for a while with the m2ts captured with my z1 i'having new questions for you.
Once i capture hdv videos i open a PAL project(i live in SPain-EU) with theese setting :
HDV 108050i 1440x1080
Field order:upper field first
Deint Method:Interpolate fields.
I edit my project on the timeline the i have 2 render in 2 major template:
1st-HDV 108050i mpg2 template to see the hdv stuff on my WD tv HD
2nd-PALWIDESCREEN mpg2 to have it on a simple sd dvd that could be read on evry dvd player.
When i use the 2nd option should i change anything on the properties at the beginning of the project
Once i open project properties when is suggested to press the folder at the right of the "save-delete"icon?
Last question:when is useful to set deinterlace model on NONE?
muchas gracias
MM
Old July 7th, 2009, 07:52 AM   #2
muchas gracias
MM
Leave the project settings to match your original HD footage and render out as per your 2nd option Marcus.
I would De-Interlace if the footage was to be viewed on a computer rather than a TV.
Dugi Barr is offline   Reply
