-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Wow!! Neat Video Noise Suppression for Vegas!! (https://www.dvinfo.net/forum/what-happens-vegas/238825-wow-neat-video-noise-suppression-vegas.html)
Roger Shealy July 10th, 2009 04:53 PM
2 Attachment(s)
I broke down and purchased Neat Video's Pro noise suppression to use with Vegas Pro 8 after reading a thread earlier in the week on DVInfo. I love my XHA1, but it's low light performance is not stellar and it has a little more noise in some situations that the best cameras. Look at these candlelight tests with the XHA1 at +12 dB gain.
These are my first attempts with the software, and there are infinite combinations for adjusting filters and detail sharpening. I'm very impressed thus far and it only gets better from here!
Marc Salvatore July 10th, 2009 05:35 PM
Roger, I agree Neat Video is amazing. Are you using the sharpening as well? It works great because it does not sharpen the noise since it knows what the noise is in the clip.
I also use Neat video for After Effects and when using it in 16 bit mode you can get even better quality.
Roger Shealy July 10th, 2009 05:46 PM
Marc,
I haven't mastered it by any means. Any tips for sharpening you want to share?
Marc Salvatore July 10th, 2009 11:58 PM
A couple of things.
1. It is critical that when you take your noise sample inside of Neat Video that your preview window in Vegas is set to Best/Full. If not you will not get as accurate a noise sample. This is buried in the Neat Video manual but very easy to miss.
2. Make sure you choose Progressive or Interlaced to match up with the footage your treating.
3. Inside of Neat Video under the noise filter settings check the "Y" box under sharpening. Many times I find I can get get not only cleaner footage but sharper footage. It's one of the best plugins I've used.
Regards, Marc
Originally Posted by Roger Shealy (Post 1170134)
Marc,
Roger Shealy July 11th, 2009 04:45 AM
Marc,
Thanks. I've been using "Best/Full", but didn't realize its importance. I'll dig into sharpening a little deeper.
Marcus Martell July 11th, 2009 06:47 AM
How much does it coast?
Marc Salvatore July 11th, 2009 09:11 AM
No problem Roger. I usually edit in preview mode so I did not discover this till I sat down and read the manual.
As far as the cost I paid 99.00 and I think it is still the same. You have to buy a new version for each software program you want to use but they do give Vegas users the 64 bit version upgrade for free.
Michael Hutson July 12th, 2009 09:27 AM
Thanks for taking the time to share, Roger. Impressive.
Martin Wiosna July 12th, 2009 09:34 AM
my only complaint is that its so slows down the rendering times.
A 20 minute video almost took 2 hours.
Martin Wiosna July 12th, 2009 09:36 AM
Pro version was $99 for Sony Vegas
Roger Shealy July 12th, 2009 02:42 PM
Martin,
My renders slowed down, but not 6x. More like 1.5 - 2.0x on SD. I haven't rendered a significant HD yet, but it's coming up.
Ian Stark July 12th, 2009 02:53 PM
I am a fan of Neat as well. It can also be used as an interesting artistic effect. I used it in this way on the title sequence and specific segments of a documentary I made last year. I applied very extreme settings which really softened the image up nicely without blurring.
Outstanding tool.
Bryan Daugherty July 24th, 2009 11:46 PM
I have been looking for something like this! Who do you order it from and is it compatible with Vegas Pro 9a?
Ian Stark July 25th, 2009 12:18 AM
Neat Video - best noise reduction for digital video tells all!
Roger Shealy July 25th, 2009 04:53 AM
Martin,
I've had the opportunity now to use Neat on several HD projects, and it does slow things down more than HD as you suggest. I haven't done a comparison, but it's probably more than 2x.
Still, this is one of the greatest tools I've come across. I've had great success restoring old footage (Sony 8mm!) and making good footage look really good.
Bryan,
Yes it is supposed to be compatible with Vegas 9. Be sure and get the Pro version for $99 so you can do HD.
