Photoshop Resolution Settings for HD Video at DVinfo.net
Old August 23rd, 2009, 06:33 AM   #1
I recently made an intro tile using Photoshops Default setting of 72dpi. I added text and an image to it (JPEG) The image and text "fall apart" pixelate etc when shown on my HDTV.
What resolution do i need to make the text, images, etc so that it doesnt look bad?
I found this thread, but got lost when they started talking about scanning images.
http://www.dvinfo.net/conf/what-happ...op-images.html
Vegas 8.0c (Build 260)-(Upgraded to Sony Vegas 10 pro)Canon GL2, Canon HV30, HF200, HF20-Sony UWP Wirelesss Mic Kit, Intel Core 2 CPU-6600@2.40GHz-3.00GB Ram
David Ruhland is offline   Reply With Quote
Old August 23rd, 2009, 06:49 AM   #2
even for SD I make everything I do in PS 300 dpi.
It also seems that Lucinda Sans works better than Arial. MAybe it doesn't but to my eye, it seems to hold together better.
Don
Old August 23rd, 2009, 07:45 AM   #3
David, if you have vegas installed just open photoshop
File New
Then in preset you will have a "Film and Video" option. Select this.
Now in "Size" you can select the presets for HD.
mintyslippers.com
Danny O'Neill is offline   Reply With Quote
Old August 23rd, 2009, 08:11 AM   #4
Danny,
I do this, but the presets are at 72dpi. This is where my problem is coming i think. Thie image i posted was one of the presets
Old August 23rd, 2009, 08:47 AM   #5
I suspect the colors involved with your image could be changed and it would work out better for you.
Old August 23rd, 2009, 09:03 AM   #6
dpi is for printing, it has nothing to do with video, just go to New/File and set your width in pixels to 1920 and height to 1080 and create your text in it.
Khoi Pham
www.proeditproductions.com
Khoi Pham is offline   Reply With Quote
Old August 23rd, 2009, 09:05 AM   #7
David, create your own custom Photoshop presets if you have to and ignore dpi as it's a print term and has no relation to video.
Pixel size is the only thing you need to be concerned about.
The only time I'm interested in dpi is when I'm scanning images and, even then, I look at what the final image size in pixels will be at a specific dpi setting.
My rule of thumb is that 1" of image size at 100 dpi = 100 pixels.
I generally scan at 150 dpi.
Therefore, a standard sized photo (6" x 4") comes out to 900 x 600 pixels.
This is slightly larger than needed for NTSC (720 x 480) so I can do some mild zooming if desired.
At 200 dpi, this same image would be 1200 x 800 pixels, at 300 dpi it would be 1800 x 1200 pixels, etc.
Scanning Basics 101 - All about digital images, the website I mentioned in the thread you referenced, has a few pages dealing with the issue of dpi and video.
Old August 23rd, 2009, 09:11 AM   #8
Khoi is right. DPI is for printing. You're using red on a black/white background and this combination is very poor. Red for titles can work, but certainly would not be my first choice. Your background changes from black to white and this is also a poor choice IMO.
Your design is the problem, not the image quality.
Old August 24th, 2009, 05:31 AM   #9
Okay, starting to get the just of this, but lets say i want to use an image as a background intro and lay text on it , Do i need to reduce it to 72dpi as well?
Old August 24th, 2009, 06:09 AM   #10
Ignore dpi, it means nothing in video.
Old August 24th, 2009, 06:21 AM   #11
Thanks Jeff!
Its part of that learning curve going from still photography to video! Sometimes I feel like a newborn calf-standing for the first time!
Thanks again
Old August 24th, 2009, 09:58 AM   #12
720 x 480 is SD resolution. Try creating a title that matches the frame size of your project. For HDV, I create 1440x1080 with 1.13 pixel scaling within photoshop.
Old August 24th, 2009, 10:01 AM   #13
Also, your full range gradient will kill any encoding scheme. Try not to apply gradient in that extreme (from full white to full black). Also, pure red or a block of red is very difficult to encode well in video. Also try to import the PSD file or export in PNG to reduce compression artifacts. JPEG doesn't work well with line art.
Taky Cheung is offline   Reply
