DVDA - Blu-Ray Workflow at DVinfo.net
Old September 4th, 2009, 07:32 PM   #1
The Situation: I have shot a wedding with Canon A1/HV20 in 60i; I have converted to the Cineform codec and edited in Vegas; I want to deliver on HD Blu-Ray.
The Assumptions: Given that I don't care about the 24p look, I assume the best project settings in Vegas are 29.9/fps@60i.
The Quesitions: Should I render the output to .avi Cineform interlaced at 60i@1920x1080? Specifically would you render out to Cineform or some other format? What would your DVDA settings be for best flicker-free results?
The Problem: My render looks excellent but my Blu-Ray flickers on my pc and will not play properly on a Sony Playstation3 which I was using to test it with.
Jonathan Gentry is offline   Reply With Quote
Old September 6th, 2009, 08:26 AM   #2
I beleive you can select Burn - Blu-Ray from the tools menu. Or, you can render to MPEG2 or AVC then use DVD Architect.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old September 6th, 2009, 08:43 AM   #3
I render to mp2 blu-ray template 1440X1080 60i. Since you used cineform files you may need to render to 1920X1080 instead of the setting I used, I don't know. What I do will play back fine from a blu-ray stand alone player, but I have not tried it on a PC or Playstation 3.
Willard
http://pawildlifephotographer.blogspot.com/
Willard Hill is offline   Reply
