My Wish List for Vegas 6 - Page 3 at DVinfo.net
Old March 3rd, 2005, 11:21 PM   #31
I had no idea this existed; Question:
I tired this technicque onthe timeline and it put a RED Border either on Left or Right (Depending on what key I selected of course) and when hitting delete it removed the same Event no matter which side.
I wanted to:
S split the Event
Select a Key for LEFT or RIGHT
and have the option of either deleting LEFT of the SPLIT or RIGHT of the SPLIT
Am I missing something here? I am trying to understand.
John Hudson is offline   Reply With Quote
Old March 4th, 2005, 09:20 AM   #32
Sponsor: JET DV
The "[" and "]" keys set the "editing mode" - that's the reason you saw the red outlines.
When you press "S", it splits and the right side is automatically selected. When you then press "[", it puts the clip on the right side into "edit mode". Pressing "[" again puts next event to the left (i.e. the event to the left of the split) into edit mode - therefore selecting it. That's why this procedure will work.
Alternately, the 7 key on the numpad will also do the same as "[". Do a search in the help file to find out more about editing with the numberpad. You can do all sorts of editing using only the numberpad.
Old March 4th, 2005, 01:03 PM   #33
Thanks again Edward
This is exactly what I have been wating to do since I started using Vegas; I'll be sure to take a xloser look at 'Key Commands'.
Thank you!
Old March 4th, 2005, 03:50 PM   #34
Here is another wish: adopt Photoshop's filter model. Let each filter have its own opacity, mask, and blend mode.
Emre Safak is offline   Reply With Quote
Old March 4th, 2005, 09:24 PM   #35
<<<-- Originally posted by Emre Safak : Here is another wish: adopt Photoshop's filter model. Let each filter have its own opacity, mask, and blend mode. -->>>
I'm kinda unclear on what you mean: You mean like the ability to fade filters (Edit/Fade)?
Van Lam is offline   Reply With Quote
Old March 4th, 2005, 10:55 PM   #36
Close...I am talking about adjustment layers (speaking of which, there are rumors that the next version is going to have all filters as adjustment layers.)
