Vegas Video discussions from 2005 (Q3Q4) - Page 29 at DVinfo.net
Old August 23rd, 2005, 08:22 AM   #421
Sponsor: JET DV
In vidcap, uncheck preview audio under options. As a warning, it may not be advisable to do both at the same time. Not all machines are up to that task so definitely test before doing so.
Edward Troxel is offline
Old August 23rd, 2005, 08:27 AM   #422
Sponsor: JET DV
Are you seeing ANY effects at all in the preview screen? If not, you possibly clicked on the "Split Screen" button (above the preview screen - it's a circle that's half dark and half light).
Old August 23rd, 2005, 10:25 AM   #423
Thanks for the help
Thanks Ed,
I'm running a P4 3.2 HT with 1 Gb Ram. I did drop a few frames (about 100) but nothing I can't edit around. The first capture totally screwed up. I had to recapture. It seems to be OK now.
I may just wait until I'm done this show and THEN capture.
Thanks again.
sincerely,
ian
Ian Slessor is offline
Old August 23rd, 2005, 10:29 AM   #424
Sponsor: JET DV
That's the problem (and about 100 frames too many dropped).
Old August 23rd, 2005, 01:06 PM   #425
cleanup stray pixels in a frame
greetings all:
Every once in awhile my camera will record a frame or two of stray pixels of a different color than what's behind them and dispersed randomly throughout the frame. Looks really bad. I guess this is b/c of dirty tape heads or something like that. I'll work on fixing it on the front end.
But, in the meantime I've got to use some footage like this for a wedding video, so my question is this: in Vegas 5, how do I minimize the appearance of these guys while keeping the rest of the frame intact? Is it possible? I know I won't be able to get rid of them entirely, but I'd like to make it less noticeable when the frame goes suddenly blotchy.
Thanks and write back if you need more info on the problem. I'm guessing you guys have seen this before, though.
Luke Duncan is offline
Old August 23rd, 2005, 01:37 PM   #426
Sponsor: JET DV
Excalibur has a "Fix Bad Frame" tool which works by simply duplicating the good frame just before the bad frame and replacing the bad frame with that good frame. You might try doing something of that nature (depending on how many frames in a row are bad).
Old August 23rd, 2005, 02:29 PM   #427
I've had issues even trying this one out. I just wanted to see if I could do it, and I had many a drop frame! If you don't have the time to do it right, when will you find the time to re-do it? As an istructor once told me!
We learn by doing, we learn better by making mistakes!
Devin Eskew is offline
Old August 23rd, 2005, 04:18 PM   #428
I wonder if the title for my thread has turned people off to answering it. It seems as if it was a good question. Anybody?
DJ Kinney is offline
Old August 23rd, 2005, 04:24 PM   #429
I would pretty much go in the order you listed but render to 24p AFTER appling the effects. Work it like any other Vegas project, pick the clips, apply effects make sure its all as you want it THEN render.
I rarely do any 24p conversion so I can't help you on that.
Don
Don Bloom is offline
Old August 23rd, 2005, 05:31 PM   #430
Thank you very much, I get it now.
Kevin Red is offline
Old August 23rd, 2005, 05:33 PM   #431
ok, I'll give it a try. I've got two bad frames in a row.
Old August 23rd, 2005, 06:04 PM   #432
"Maybe a Magic Bullet film look here and there."
Only if you want to increase your render time at least 10 fold :-(
Every post I've ever read about it says it's a real render hog.
Celluloid ($25 from the VASST site) is supposed to be far superior - and much quicker as well.
Mike
Mike Kujbida is offline
Old August 23rd, 2005, 07:50 PM   #433
Sponsor: JET DV
If you have 1BB2 (where B are the two bad frames), you could try changing that to 1122 and see how it looks.
Old August 23rd, 2005, 11:41 PM   #434
Adding Transitions To The Entire Video
Hey Guys and Gals,
I am just curious as to how you would go about adding one transition to the entire video. My video is only on one track if that helps. Cheers
Scott Johnston is offline
Old August 24th, 2005, 02:40 AM   #435
cool thanks dudes
Michael Kristen is offline
