Vegas Video discussions from 2005 (Q3Q4) - Page 31 at DVinfo.net
Old August 25th, 2005, 12:56 PM   #451
I may have misunderstood...
Hi Ed,
Yeah. I may misunderstand.
I have no problem with everything being appropriately linked.
I have more of an aesthetic concern.
As noted each submenu of four dances has all of the submenus listed at the bottom of the page. 1 to 4 5 to 8 etc.
When I return to any of the submenu pages it's the "1 to 4" link that is always highlighted. I was hoping that when I returned to, say, the "9 to 12" submenu that the "9 to 12" link would be the one that's highlighted.
A niggling thing I realize but then I'm a little... picky about my work.
Thanks again.
sincerely,
ian
Ian Slessor is offline
Old August 25th, 2005, 01:21 PM   #452
Sponsor: JET DV
And if you change the setting I mentioned, THAT is what will happen. It specifies WHICH button is to be highlighted.
Edward Troxel is offline
Old August 25th, 2005, 01:49 PM   #453
My momma always told me to listen.
I should have listened to momma...
and Ed.
Thanks for the help.
sincerely,
ian
Old August 25th, 2005, 02:09 PM   #454
Vegas Chroma Key Walkthrough
Hi, i bet this has been on this forum several times but i cant find it in the search.
Could someone please walk me through chroma key step by step? i can get started but i cant figure out how to get the picture i want instead of the removed color.
Matty Munson is offline
Old August 25th, 2005, 02:16 PM   #455
Sponsor: JET DV
Track 1: Green screen clip
Track 2: New background clip
Add the chromakey effect to the clip on track 1 and use the eyedropper to pick the color of the background color.
Old August 25th, 2005, 02:47 PM   #456
so i cant ad my own image or video as the background then?
Old August 25th, 2005, 02:53 PM   #457
Sponsor: JET DV
Yes you can. That's what's on track 2!
Old August 25th, 2005, 03:03 PM   #458
oh *der*
Sorry misread your reply.
thanks
Old August 25th, 2005, 04:02 PM   #459
Keith Kolbo's article, "Chroma Keying DV in Sony's Vegas", at http://www.broadcastnewsroom.com/art...e.jsp?id=31596 is an excellent tutorial.
Mike
Mike Kujbida is offline
Old August 25th, 2005, 04:46 PM   #460
Effects issue
Just upgraded Vegas 4 to 6. Anyway, after reading the 400 pages of manual, I can't seem to find my likely simple answer.
Question: Why do all my effects only appear in half of the image?
Thanks in advance.
Derek Weiss is offline
Old August 25th, 2005, 04:50 PM   #461
On the preview monitor there is an icon that switches "splt screen" on/off. Turn it off.
Jim Montgomery is offline
Old August 25th, 2005, 04:55 PM   #462
Thanks, so simple.
Old August 25th, 2005, 05:15 PM   #463
Thank you for your responses. I will surely play with your suggestions and hopefully they will give me that smooth event change that I am looking for.
Brian, what do you mean by "quantize to frames" and what is hard cutting?
If i understand it correctly, that the little triangle in the upper corner should be dark blue when 2 clips are butted together. Should there be any overlaps like .1 seconds?
Thanks again!
Danny
Danny Santos is offline
Old August 25th, 2005, 05:24 PM   #464
A "hard cut" is probably not a real editing term, but what I meant was a cut from one clip to the next, rather than a cross-fade transition.
"Quantize to frames" makes the clips snap to the frame boundary grid when you move them. If you have your cut in the middle of two frames rather than right at a frame edge, it may render funny and that could be causing your problem. There is a button on your toolbar that turns quantizing on and off, and you can also toggle it with ALT+F8. You should keep it on when editing video, and can turn it off when doing the audio if you need to make movements of a fraction of a frame. It should be on by default, so it's probably not your problem.
Yes, the little triangles in the corner should be dark blue when the two video clips abut each other and you aren't cross-fading. If they are light blue, there is some fading in and out going on. Also, you might try a very quick cross-fade of just a few frames to see if that helps, too.
Brian Kennedy
Brian Kennedy is offline
Old August 25th, 2005, 09:58 PM   #465
Splendtastic
Thanks Edward
Scott Johnston is offline
