Vegas Video discussions from 2006 (Q3Q4) - Page 56 at DVinfo.net
Old September 23rd, 2006, 05:13 PM   #826
Yes. NewBlueFX and Pixelan both offer a "Posterize" feature in their plugin suites.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old September 23rd, 2006, 07:09 PM   #827
Question about 4:3 to 16:9
I have edited a video for a company. This video was shot in 4:3. It now turns out that this video will be on a 50" plasma at this years SEMA show. Can I render this 4:3 video to work and it will be full screen on the tv?
I did this once beofore and it seemed that everything that I edited didn't move. I hade space at the top and the bottom and like normal on a 16:9 widescreen but my text that I had originally added was now in the black spaces.
Thanks, Jason
Jason Simpkins is offline
Old September 23rd, 2006, 07:38 PM   #828
Sponsor: JET DV
Take a look at the "Split Screen" article in Vol 3 #1 of my newsletters. It shows multiple methods including the use of a Black/White generated media which you can substitute your image for.
Edward Troxel is offline
Old September 23rd, 2006, 07:57 PM   #829
Notebook for Vegas 7
This is a PC question but I want to target the PC for Vegas so posted here... hope it is correct forum...
I am almost convinced a notebook can handle HDV editing and am thinking of getting one for this purpose. My projects usually use a Sony Cam (Z1U) for capture, I usually use Sony Vegas for editing... and now I am thinking of a Sony Vaio Notebook for the editing machine. In your opinion or experience would this machine handle HDV pretty decently?
Sony Vaio
Windows XP Pro
NVIDIA GeForce Go 7600 (shoot... doesnt say how much memory)
Core 2 Duo T5600 (1.83 Ghz)
1GB Memory
100GB HD (5400rpm)
I figure Sony, Sony, Sony... things will run REALLY smooth... however am a bit concerned about the HDs spinning at only 5400... I have used trusty old SCSI drives for years now and they have never let me down...
what do you think?
Carl Downs is offline
Old September 23rd, 2006, 09:17 PM   #830
Keyframes?
Again... I appologize for the simple questions. I'm trying to get up and running on Vegas 7.0. I've looked around for a while for the answer to this. Perhaps I'm not using the correct phrasing in my search.
In P-Pro you can simply fade in and out of a clip using the keyframes. I can't seem to figure out how to perform this simple task in Vegas. That goes for motion and scaling too. Any help would be appreciated. Or perhaps point to the right thread.
Thanks..
Tim Bickford
Tim Bickford is offline
Old September 23rd, 2006, 09:42 PM   #831
In Vegas, turn the opacity envelopes on. I think there are opacity envelopes...
There are also the cross-fades of course. You need to mouse over the upper corner of a clip, and then drag left/right.
2- Motion and scaling is controlled by the pan/crop window. There are probably tutorials for this, but I haven't read them.
Edward Troxel has a free newletter with good tutorials.
There are also lots of free resouces on the VASST website. vasst.com
List of tutorials:
http://www.vasst.com/training/Tutorial%20link.htm
Glenn Chan is offline
Old September 24th, 2006, 01:56 AM   #832
When I buy a new laptop with Vegas and Adobe CS in mind it will probably be an Alienware. I would not get hung up on all Sony. Just my opinion after spending 5 years at the happy M ranch in Redmond.
Konrad Haskins is offline
Old September 24th, 2006, 05:15 AM   #833
be aware that alienware have just been bought out by dell, so by the time u decide, u may end up buying piles of bloatware...
I recently bought a Toshiba A100 Pro
dual core@1.73, 1gb ram, 80gb drive, 256mb Nvidea display (dedicated) and i can run magic bullet through after effects in realtime... multi burner, and a 15.4' screen (which is equivalent to one of 17' CRTs
Cant fault it, Im using V6, and edit HDV for corp clients with it. I also use it on photography gigs and dump CF cards onto it as i work... It runs CS2 without skipping a beat
Superfast, BUT i run an external media drive for ALL video... much easier and less wear and tear on the main system drive. Considering theyre mobile's theyre going to be knocked arond a bit, so IMO its just a safer bet
Peter Jefferson is offline
Old September 24th, 2006, 08:45 AM   #834
Dell bought Alienware back in March. The deal was they would keep doing their own thing. Do you have any evidence that big evil Dell has scr*wed up Alienware? The good news is you can buy DEll Dell 24" 1920 x 1200 UltraSharp Widescreen bundled with Alienware for around $600.
Old September 24th, 2006, 10:08 AM   #835
...but that is what should happen when you resample. Did you try adjusting the event's playback rate and undersample rate by right clicking and selecting Properties? Setting the undersample rate to 20/25=0.8 should do the trick.
Emre Safak is offline
Old September 24th, 2006, 12:15 PM   #836
Sponsor: JET DV
Tim, Vol 2 #8 has an article on keyframing.
Old September 24th, 2006, 01:16 PM   #837
I am not satisfied by the result. Oh, no idea...
Plamen Petrov is offline
Old September 24th, 2006, 01:40 PM   #838
You might not be satisfied with the result, but Vegas is doing what you asked! Maybe you want something else, like this.
Old September 25th, 2006, 04:17 AM   #839
good way to downconvert to SD?
Read this on the net as a possible workflow, think it'll work in vegas? Lots of mixed reports about HDV downrezzed to SD. Is this the answer?
capture in cineform>render cineform timeline to CF movie> use procoder II to transcode to m2v at 720x480, 16x9, par 1.2, upper field FIRST > dv architect to burn.
Has anyone tried this?
Brian Luce is offline
Old September 25th, 2006, 05:26 AM   #840
I haven't tried it, and I won't because I'm from a PAL-country. Anyhow, I would change one thing for sure: if you captured HDV with the JVC, then it is progressive, so I would choose a progressive SD format to downconvert to....
Werner Wesp is offline
