Vegas Video discussions from 2006 (Q1Q2) - Page 110 at DVinfo.net
Old May 22nd, 2006, 08:23 PM   #1636
Sponsor: JET DV
NOTE: some people have lost some of the default effects when uninstalling Vegas 5. If this happens, first try reinstalling Vegas 6 and if they're still gone reinstall Vegas 5.
Edward Troxel is offline
Old May 22nd, 2006, 09:08 PM   #1637
Originally Posted by Fred Foronda
After many attempts to get the supplied CF codec to work and Vegas was not operating correctly I had re-booted my computer. Vegas 6 software (CD) is not able to install anymore. Anyone knows whats going on? I will try tech support but they're closed at the moment.
Is you're computer a little older? vegas 6 won't install on older computers sometimes., I had to use vegas 5.
Brian Luce is offline
Old May 22nd, 2006, 09:32 PM   #1638
Thanks, I had forgot of that alternative.
Canon C100, 5D3
Jeff Baker is offline
Old May 22nd, 2006, 09:44 PM   #1639
Nope, I previously had it up and running until I added the Connect HD trial verison. When it expried thats when I started to have problems. Thats why I rebooted my computer.
Fred Foronda is offline
Old May 22nd, 2006, 10:03 PM   #1640
So Let Me Get This Straight
I'm new to HDV, via the A1U. I've been using Vegas since version 2, I believe. So let me get this straight:
In order to edit realistically in Vegas with HD footage, you have to render it down to DV. Then after you edit, you have to render again. But there' s no real point in rendering to HDV, because there's no real mechanism for delivery.
Am I understanding this correctly?
What's the difference between doing the conversion in Vegas and doing the conversion in the A1U during output/capture?
Rob Gregory-Browne is offline
Old May 22nd, 2006, 10:07 PM   #1641
Conversion in-camera:
You can never recapture frame accurately to have an HD master. YOu can only ever have an SD master.
Conversion in Vegas:
you can have an HD master, SD master, HDV master.
The rest is debatable. Although it takes longer, I prefer to convert in Vegas.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old May 22nd, 2006, 10:18 PM   #1642
Basically...SD is now pretty much the only delivery opton, but with viable HD delivery options in the near future it is good to have an HD back up. You are actually not rendering the video to dv (atleast I don't believe) in vegas. You would use an intermediate codec which is similar to a layer in photoshop. You can then edit the video without degrading as much as you would by rendering the HD to DV. You then, from there, can go back to tape as HD or render to SD for DVD purposes (or for computer, etc..)
Michael Stowe is offline
Old May 22nd, 2006, 10:21 PM   #1643
If it is a ConnectHD issue you should uninstall, which I am sure you have done. You also may need to get rid of the registry entries that are left behind which I will not get into since there is a risk involved with this. I just recently reinstalled Sony 6 without issue and had a trial version of ConnectHD onboard. What is the exact error you are getting?
Old May 22nd, 2006, 11:28 PM   #1644
Okay so what stops me from doing the following:
1. Do the conversion in camera during capture.
2. Edit in Vegas.
3. Render as needed in SD.
4. If and when I need an HD version in the future, simply recapture the original footage in HD and replace all the SD footage with the HD footage in the Media bin.
5. Render to HD.
I'm not sure I understand why this wouldn't work.
Old May 22nd, 2006, 11:29 PM   #1645
I load the cd and the intro vegas screen pops up along with the funky music in the background with the selections. I click on install vegas there a very long pause then an error comes up and reads: "Set up.exe Application error. The application failed to initialize properly (0XC0000006.)" That don't look so good. Should I reboot again?? This is so time consuming spent all day trying to figure this out.
Old May 23rd, 2006, 06:48 AM   #1646
You were right John, Gearshift does force the files to be placed in the same folder. Silly me must have rendered both the DV proxy n CF files together is a different folder, den deleted the CF n tested if I could swap to m2t. Its working fine. Now to find out my other question on FX1 converted DV before I make a conclusion. Thanks again for the quick support!
Sean Seah is offline
Old May 23rd, 2006, 06:50 AM   #1647
Oh yeah.. thaz a good tip I forgot. Anyway. I cant tell because my mini preview window at the lower corner doesnt have the 2 black bars when I have a m2t or Cf files on the time line, just like DV-PAL. Thaz why I cant tell the difference. I'm not sure if there is something wrong with the preview screen.
Old May 23rd, 2006, 07:51 AM   #1648
2. Edit in Vegas.
5. Render to HD.
Nothing that I can see. Many will say you get better results letting vegas do the conversion but many say they do not see a difference. Not sure about any editing you may do from the start though. If you had a lot of editing you may want to put it back on tape afterwards rather than redo everything. The experienced on here can give you the advantages and disadvantages.
Old May 23rd, 2006, 07:53 AM   #1649
the lack of frame-accurate recapture would prevent you from accomplishing this at this time.
Old May 23rd, 2006, 08:43 AM   #1650
Ahh. Now that makes sense.
Maybe this will all be moot in a year or two when the computers have caught up to HD.
