Vegas Video discussions from 2006 (Q1Q2) - Page 116 at DVinfo.net
Old May 29th, 2006, 11:00 PM   #1726
Enable ripple, then set it to affect all tracks, markers, regions. Insert your image. Everything will shift downwards.
FWIW, it's a good idea to leave :30 at the front of any project, you may need a count, bars, whatever....or may find that you need to insert an image. :-)
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old May 29th, 2006, 11:06 PM   #1727
Wow, incredibly fast reply. Worked like a charm.
Thanks so very much Douglas
Scott Johnston is offline
Old May 30th, 2006, 09:31 AM   #1728
Vegas Video 6.0d freezes
I just purchased a computer recently expressly for being able to edit HD video. (AMD FX60 processor, 4 gig RAM) I've been having problems with Vegas Video 6.0d. It worked fine on my old Intel chip computer but it seems that this AMD based computer is having problems. I cannot "capture" HD video from my camera. The program recognizes my HC-1 camera and I am able to control the fast forwad and rewinds function but when I go to hit play or the red capture button the program freezes. I've have tried re-installing the program several times. I have updated my video card. I have updated to SP2 as well as Windows XP. My IEEE link seems to be working fine since it does recognize my camcorder when I plug it in. I have another friend who is using an early AMD chip and he has no problems. I am out of options. Any suggestions would be greatly appreciated.
Val Riolo is offline
Old May 30th, 2006, 10:59 AM   #1729
Your firewire post...is in on the motherboard (integrated or a seperate card).
I had issues way back when capturing in Vegas using my motherboards built in firewire port.
I installed a firewire card, disabled the onboard firewire in the system BIOS, and all was well.
Michael
www.lvpvideo.com
Michael Liebergot is offline
Old May 30th, 2006, 07:10 PM   #1730
Jubal 28
Ripples are extremely powerful. Just be sure to disable it before you do anything else!
David Jimerson is offline
Old May 30th, 2006, 07:45 PM   #1731
Sponsor: JET DV
A couple of other options in addition to Ripple:
Put the cursor at the beginning of the timeline and choose Insert - Time
This will let you insert any specific amount of time at the cursor position.
Since you're moving EVERYTHING... you could always press CTRL-A to select everything in the project and then slide it however far you want.
Edward Troxel is offline
Old May 30th, 2006, 09:08 PM   #1732
Copying bezier mask
It's my first time working with Vegas 5 pan/crop feature. I have some archival photos that I'm working with. I'm having a lot of fun and the pan/ crop is working and looking better than I expected, but I have one problem. When I try to copy the mask from one type of clip ( a .tif photo image) to a dv video clip, the size of the mask is changed on the second clip.
In "Vegas 5 Editing Workshop" (which usually is worth it's weight in gold) it says to copy/paste the keyframe from clip a to clip b and the mask will maintain it's aspect ratio. I tried this and it does not seem to work. Maybe I'm not doing this right.
The only way I can get it to work is to uncheck "maintain aspect ratio" in the properties of the two events. This works except the image that I'm masking becomes distorted (it widens and looks unnatural). The image I'm masking is from a photo arranged in portrait rather than landscape.
I hope i've explained the nature of my problem well enough to understand...
Nature Boy
Phil French is offline
Old May 30th, 2006, 10:12 PM   #1733
I agree...try another firewire port. I have the AMD 64 with 3 gigs of ram and no issues capturing HD. I am sure you have the correct settings in Sony vegas? Are you able to capture with ConnectHD from Cineform which is a very nice program to work with HD footage. Unless something is screwy with the Sony settings, I don't think this is a Sony software issue although I am not sure with the AMD FX.
Also...try setting your cam to downconvert to SD and then try capturing that in Sony V. Does that work?
You also might try asking around in the "What happens in Vegas" section of the HD editing forum below this one.
Michael Stowe is offline
Old May 31st, 2006, 04:49 AM   #1734
Thanks David and Edward
Old May 31st, 2006, 01:40 PM   #1735
David,
If you open the movie in the QuickTime player and choose Window>Show Movie Info, what is the format listed as?
Christopher Lefchik is offline
Old May 31st, 2006, 05:01 PM   #1736
Firewire
Thank you so much for your suggestions. I will try installing a seperate firewire card.
Old May 31st, 2006, 07:05 PM   #1737
Similar Problem
Sometimes when I render to quicktime format, my newly rendered file displays a black screen but the audio is there. But if I stop playback and manually move the playback slider I can see the movie as intended. Any thoughts?
Rob
Rob Kraneveldt is offline
Old May 31st, 2006, 09:20 PM   #1738
Need Help Captureing
Hi, I dont know where to put this, sorry if I posted it twice. I have problem capturing mini dv footages from my panasonic dv953. I have Vegas 5.0, I dont think it's the soft ware, can the vegas capture footages from this camera? It dont have a fire wire port, just a USB. When I do connect, this message comes up,
"Digital video camera is not set correctly.
Connect USB cable to your PC and
set digital video camera to the [Web Camera] mode.
If ready, press the [OK] button."
Is there a way for me to capture footages from this camera?
Thank you.
Sam Looc is offline
Old May 31st, 2006, 10:50 PM   #1739
Use firewire to capture. There is a firewire port on your camera somewhere... the manual can be downloaded if you're having trouble locating it.
If your computer doesn't have a firewire port, get a firewire card + 6pin-4pin firewire cable. They are about $25 (bundle) for people living in the US.
newegg.com
pricegrabber.com
pricewatch.com
resellerratings.com
The USB port is for capturing low quality MPEG4 video (something like that), and the firewire port for DV.
Glenn Chan is offline
Old May 31st, 2006, 11:12 PM   #1740
Ah, I found the fire wire port! Thanks alot for pointing me to the right direction.
Sam Looc is offline
