Vegas Video discussions from 2006 (Q1Q2) - Page 138 at DVinfo.net
Old June 28th, 2006, 03:18 PM   #2056
Sponsor: JET DV
Move the files. When you open the project the next time, it will ask where those files are. Point it to the new location.
Edward Troxel is offline
Old June 28th, 2006, 03:26 PM   #2057
Do you think something like that would be useful for me? Maybe a plugin or something that automatically shrinks a double-click-selected region by a frame?
brah
Sounds bleak, don't it?
Mathew Kurtz is offline
Old June 28th, 2006, 03:33 PM   #2058
Right you are. Score another one.
Emre Safak is offline
Old June 28th, 2006, 08:24 PM   #2059
Sponsor: JET DV
In my case, shrinking by a frame did not work. I had to make sure the frame before and after the region was not there (actually, I just deleted everything before the region and everything after the region).
Old June 29th, 2006, 12:55 AM   #2060
pan crop for non proportional video?
i have a part of a video i need to take from another video , the screen is split into two vertically (i need left side).The part i need is not perfectly square (height is longer than width)
i tried pan crop but it only goes zooms in and out in perfect squares, anyone know how i can crop out this rectangle portion within vegas,i know when i isolate that section and fit to screen in it will look kind of messed up because proportions are not right but that is ok. Just need that section
thanks in advance
Pete Peterson is offline
Old June 29th, 2006, 05:03 AM   #2061
Project Time
I'm just thinking out loud here, but I wonder how hard it would be to have a script in vegas that tallys up your work time on a project?
Steven Davis is offline
Old June 29th, 2006, 07:07 AM   #2062
Sponsor: JET DV
Pan/Crop WILL do it - you just need to turn off "Lock Aspect Ratio" (it's one of the buttons down the left side of the Pan/Crop dialog).
For more info on creating masks which will also let you do this, take a look at Vol 3 #1 of my newsletters.
Old June 29th, 2006, 12:16 PM   #2063
Resetting vegas window setup to default
I recently switched from Twom small monitors to a 24" and a production monitor and would like to reset vegas to the default setup, but I can't figure out how!
I have all kinds of windows all over the place and when I drag them to the bottom they create a seperate frame instead of a tab on the lower left. It gets pretty crowded!
Kevin James is offline
Old June 29th, 2006, 12:20 PM   #2064
Try this: http://www.dvinfo.net/conf/showthread.php?t=70226
Old June 29th, 2006, 12:24 PM   #2065
Perfect! Thanks for the link to that thread!
Old June 29th, 2006, 03:14 PM   #2066
Changing the volume globally
I have a project with many audio tracks, each with a volume envelope. How can I adjust the overall volume? I want everything raised by 12dB throughout the file. Normally the output faders can facilitate this, but I have maxed them out, so I think I need to adjust the envelopes.
Old June 29th, 2006, 03:16 PM   #2067
Sponsor: JET DV
I guess you could route them all to a bus and then raise the volume level on that bus.
Old June 29th, 2006, 03:42 PM   #2068
Does it matter if it is a surround project? It seems routing to busses is only possible when you are not using a surround master.
Old June 29th, 2006, 04:02 PM   #2069
Not sure if this will work for you but it's worth a shot.
View - Audio Bus Tracks
Insert a volume envelope on this new "Track"
You can raise the volume on each of these independently plus the volume controls on the master faders.
Mike Kujbida is offline
Old June 29th, 2006, 04:14 PM   #2070
You da man. That gave me another 6dB of leeway. The tricks some people have up their sleeve!
