Importing MP4 files shot with EX-1 at DVinfo.net
Old June 3rd, 2010, 01:32 PM   #1
Hi all,
I am about to edit a project shot with a EX-1. Last time I edited a project shot with this camera I had to import each clip individually, which wasn't a hassle because the entire project was shot over 3-4 takes.
Now my current project has 300+ shots and I would love to import them all at once. I shudder at the mere thought of having to go into each folder and import the files individually.
I couldn't find a way to do that last time around, do you have any tips regarding this issue?
Phil
Phil Gosselin is offline   Reply With Quote
Old June 3rd, 2010, 03:31 PM   #2
Vegas Pro 9 has full support for EX-1 import in View/Device Explorer.
Previous to ver 9 there is this tutorial
Sony Creative Software - Training - Vegas Pro XDCAM - XDCAM EX workflow
Hope this helps.
Ike
Ike Tamigian is offline   Reply With Quote
Old June 3rd, 2010, 04:20 PM   #3
Hi Ike,
Problem is that I don't have the device, just the files.
Thanks for the pointers though because I opened the Device Explorer and the the source to a root folder instead of a device. That did it, all the clips were seen and Vegas is importing them as I type.
Cheers,
Phil
Old June 3rd, 2010, 04:28 PM   #4
Device Explorer doesn't need the actual device. Just the SxS card or an external storage device with the correct dir/file structure from the EX series.
Glad it worked. Have fun.
Ike
Old June 3rd, 2010, 05:44 PM   #5
Or even the local hard drive with the same file structure.
Adam Stanislav is offline   Reply With Quote
Old August 27th, 2010, 12:30 AM   #6
How does one create the right file structure so the drive is visible? I have all of my clips on one HD, but the drive letter doesn't come up.
Thanks.
Craig Kovatch is offline   Reply With Quote
Old September 1st, 2010, 11:06 AM   #7
If I understand your question correctly: On my system I have to tun on the device BEFORE I start up Vegas to make it appear in the explorer tab.
Charles Newcomb is offline   Reply With Quote
Old September 1st, 2010, 01:20 PM   #8
Even though Vegas Pro 9 takes native MP4 XDCAM EX files I still find it easier to convert the files to MXF's then just drag and drop them into your project.
The BPAV directory structure for created for the native files is a pain to work with IMHO.
-Garrett
Old September 2nd, 2010, 09:44 PM   #9
"The BPAV directory structure for created for the native files is a pain to work with IMHO."
this is what I do working with native files:
... located on your BPAV folder just make a search for *.mp4 in your windows explorer window and ALL the native mp4 files appears together... in the sequence you want ... then just drag and drop on project... very easy and no need to have extra space for mxf files....
my 2 cents
Enrique Orozco - Sony/JVC/Nikon/Panny cams, DJI/Yuneec drones, VegasPro
www.aerofilm.com.mx
Enrique Orozco Robles is offline   Reply With Quote
Old September 3rd, 2010, 08:36 AM   #10
Hey Enrique,
This is one of those situations where you get so use to doing things one way you don't see the easy solutions in front of you.
Garrett
Garrett Low is offline   Reply
